Bad wiring?
Old Oct 31, 2012 | 01:46 PM
Darryl Cummings's Avatar
Darryl Cummings
Default Bad wiring?
So I recently bought a 2003 about two weeks ago and immediately the day after, I had to replace the alternator. The car seemed to run fine for the next week and a half but then after I bought a brand new battery, the alternator cut out completely. It kicked back on about halfway home but then stopped working ever since.
When I decided to take out the brand new alternator and have it tested (and it tested good), I noticed that the top-most bolt (which I'm assuming is the bolt that grounds the alternator) was barely even tightened down. But the most alarming thing was after I got the whole thing out, the positive post was heavily corroded, like somebody just took a bite out of the post, there's no way after just two weeks would something look like that.
So I got the new alternator replaced and made sure this time that everything is tightened down correctly on the way in. But the same thing is already starting to happen, the first time I started the car it held steady at around 14.9v but after refilling the radiator and taking the car on a drive, the voltage started at around 14.9 but was dropping steadily over time and now reads around 12.3v-13v idle and 14v whenever I start to drive.
Now since I haven't had a working alternator so far, is that normal? Does your Z's fluctuate like that? Also, do you think that maybe there is a short affecting the positive terminal? I don't know of anything else that could cause that kind of corrosion.
Don't know if any of this helps but I've noticed the car has an aftermarket radiator, APS Plenum, UR underdrive crank pulley, aftermarket tailights, and I can tell that the car had an aftermarket stereo at one time because there are still wires for the amp and sub, but it's been since taken out.
EDIT: I can confirm that the reason the voltage doesn't drop when I first start the car is because the car idles a little bit higher to warm up, but once the car is satisfied and idles at normal rate, the voltage drops.
Old Oct 31, 2012 | 07:55 PM
grimm66's Avatar
grimm66
Make sure your battery terminals are tight and clean
Old Oct 31, 2012 | 08:02 PM
ronn1's Avatar
ronn1
Aftermarket tail lights..LED type...can cause a host electrical problems due to resistance issues that are out of spec.
Old Oct 31, 2012 | 11:03 PM
Darryl Cummings
The terminals look like they've just been replaced.
I thought this too, but I disconnected the taillights and still had the problem, not unless the problem is only fixed through connecting stock taillights.
I've tried the fuse and it's perfectly fine, the battery is brand new, and the alternator is brand new, and the upgraded ground wires look fine. I really can't think of what else it could be, I'm gonna try and see if I have a short somewhere when I get time.
Old Nov 2, 2012 | 02:36 PM
Darryl Cummings
Sorry for double post but do you guys think it might be the underdrive crank pulley? Because the voltage only drops when the car is idling around 500rpm, but if I blip it up to about 800rpm, everything's fine. So maybe the pulley is rotating the alternator too slow at idle?
Old Nov 2, 2012 | 08:45 PM
RandyK1's Avatar
RandyK1
The car should idle at 750 rpm, not 500.
Old Nov 2, 2012 | 08:54 PM
Darryl Cummings
Sorry I was going from memory, now that I look at it it is actually just under 750. But I still really think it's the pulley, I'mma try and find a stock size one.
Old Dec 6, 2012 | 06:47 PM
Darryl Cummings
Ignore this post, I kinda jumped the gun on the poblem
Justin100
Nov 25, 2021 06:26 AM
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
350z82
Oct 1, 2015 06:25 PM
