does your 350z do this....need help don't know if this is normal
Old Dec 6, 2012 | 08:27 AM
bmccann101's Avatar
bmccann101
Old Dec 6, 2012 | 09:29 AM
Nismo350z#0310's Avatar
Nismo350z#0310
Yes
http://www.youtube.com/watch?feature...=H8c0tDzyKlA#!
Old Dec 6, 2012 | 09:40 AM
SQuaLZ's Avatar
SQuaLZ
Originally Posted by JPT0117
I have a feeling it's the clutch but perhaps we should wait for a few more responses to make sure.
I think its the clutch also, just making sure the OP knows
Old Dec 6, 2012 | 10:17 AM
cow's Avatar
cow
Your engine is showing the early signs of Auto Alzheimer's. The first sign is not sensing short term driver inputs. Next it's going to poop itself.
Old Dec 6, 2012 | 03:28 PM
latinohosting's Avatar
latinohosting
mine started doing that... changed the clutch to a new one
that was supposed to be an stage2.. after 6-7 months it was doing the same thing
the mechannic said it was cause the previous clutch had messed up the flywheel...
i can recomend you... based on my own experience.. to buy the good stuff and both
the cutch and the flywheel... i mean if you are going to buy a new clutch dont buy the
cheap ones on ebay... look for an ACT clutch and the ACT flywheel...
you can get them both for like around 1000.. and also WHATEVER YOU DO please dont forget to replace the 350z Clutch Pivot Ball... with the new clutch regardless of what you do... the OEM pivot ball bolt is not as strong as needed for the job with aftermarket clutchs...
so bottom line... i had a bad clutch.. bough an exedy stage 2... 6 months later it was dong the same thing.. mechannic said.. flhyheel... and recommended the pivot ball changed.. i did and bought ACT and now its great
Old Dec 6, 2012 | 03:37 PM
350Zdj's Avatar
350Zdj
not sure if it has been mentioned yet... but the clutch needs replacement
Throw in a nice lightweight fly wheel while you're at it, as mentioned on the above post.
Old Dec 6, 2012 | 08:45 PM
terrasmak's Avatar
I would replace the clutch
Old Dec 6, 2012 | 10:39 PM
SR71's Avatar
SR71
Lead Super Moderator
Magic 8 ball says it's your clutch.
Old Dec 7, 2012 | 02:02 AM
logan09's Avatar
logan09
You dun burned your clutch out
Old Dec 7, 2012 | 10:02 AM
1LightBrick's Avatar
1LightBrick
clutch is shot
Old Dec 7, 2012 | 10:06 AM
mvp2765's Avatar
mvp2765
just a guess - new clutch?
Old Dec 8, 2012 | 10:10 AM
NFGZ's Avatar
NFGZ
If I had to take a stab at it... I'd say its your clutch... But good luck!
Old Dec 8, 2012 | 01:40 PM
mattleegee's Avatar
mattleegee
i know you havent really gotten any help here in your thread but possibly you might need a new clutch
bonus:
i think if i had it open i would also replace the flywheel, then the master cylinder, and slave cylinder to have a brand new setup
Old Dec 8, 2012 | 05:22 PM
djamps's Avatar
djamps
I assume this your first manual?
Old Dec 9, 2012 | 10:20 AM
richee3's Avatar
richee3
Just a shot in the dark here, but I'm guessing your clutch is going out. If that isn't it, then it must be the clutch. If you check that and it's good too, then it's probably your clutch.
Old Dec 10, 2012 | 09:20 PM
Dopavash's Avatar
Dopavash
The single best mod I ever did to my 04 Enthusiast was a lightweight flywheel. I went with a Fidanza and just an OEM replacement clutch. The car was so much more fun to drive after that.
Old Dec 11, 2012 | 05:25 AM
Nismo350z#0310
Knowing the way the 350z is going: It's probably his first car.
Old Dec 12, 2012 | 07:55 AM
  #38
ModBargains's Avatar
ModBargains
Vendor - Former Vendor
it's a bad clutch. it's slipping pretty bad. You might want to upgrade your clutch
Old Dec 12, 2012 | 10:21 AM
  #39
ZSpeedPerformance's Avatar
ZSpeedPerformance
Probably hit an Icy patch in the road, If not you might need a clutch.
Seriously, If you need help getting a clutch to fit your needs feel free to give us a call, We'll get you squared away.
Old Dec 12, 2012 | 12:14 PM
  #40
Esser's Avatar
Esser
don't buy a new factory clutch from the dealer like most ignorant people do, you can save yourself a lot of money by buying a better clutch for half the price of what they want for OEM.
