Car overheating, air bubble.
Old Dec 22, 2012 | 04:09 PM
amarillotx350z's Avatar
amarillotx350z
Default Car overheating, air bubble.
OK after reading through all kinds of threads I know now that the ar bubble issue that causes the 350z to overheat is somewhat of a common issue and a very easy fix. I have ecnountered this issue on my car for now at least 3 times. Everytime I have been able to resolve this issue without any problems. My question now is how often has this happened to others.... Even though it is a very easy fix I am starting to wonder where this air pocket is coming from or what is causing it. Keeping in mind that there are no apperant leaks to be found. Thanks in advance and any information would be helpful.
Old Dec 22, 2012 | 04:36 PM
NismoZ123's Avatar
NismoZ123
Well, you are aware that parts of your cooling system could blow up if you have too many large bubbles in there, just saying.. be careful over there. Coolant runs hot! Peace of mind is priceless.
Old Dec 22, 2012 | 04:46 PM
amarillotx350z
I've never actually ran the car hot just gets past a little over the middle and I know right then and there that something is going on. The first time it happened I ended up going through 3 thermostats before I investigated the issue (waste of money). It still hapenns though today being the third time.
Old Dec 22, 2012 | 06:21 PM
Sleepy79's Avatar
Sleepy79
air pocket is created by not filling your coolant slow enough, even then you should check it and top it up after bringing it up to temp (make sure you let it cool first)
Old Dec 23, 2012 | 05:00 PM
amarillotx350z
Have done that and the issue will go about 3 months or so before it presents itself again.
etkms
Jun 19, 2022 06:30 PM
SonnyWu
Nov 24, 2015 08:19 PM
Vigman
Nov 17, 2015 04:34 AM
Obeorangekenobi
Sep 11, 2015 07:17 AM
