Uneven steering, steering wheel wants to turn right!
Old Jan 4, 2013 | 06:01 AM
ehaalandtluk's Avatar
ehaalandtluk
Default Uneven steering, steering wheel wants to turn right!
Hey guys.
Symptoms of my problem:
Car goes straight if steering wheel is straight (0*-3*)
If pressure is removed from steering wheel at any speed, it will move 5* to the right and make the car start turning. This is on any driveway/flat surface (not just on highways with road droop )
If I hold the wheel straight, it drives straight.
The car is noticeably harder to turn left.
Car history:
(BEFORE I WAS A CAR NUT LOL )
Had a curbing incident in 2009, passenger side suspension was damaged and most control arms were replaced as well as the wheels. When I recieved the car back from the shop, there was some pull to the right, but I brought it back and it was fixed mostly, still some slight pull but I lived with it because I was still in school and I barely drove 4 or 5 thousand miles per year.
Mid 2011 when I started commuting, I decided to get my tires checked and wheels redaligned. Front two tires were MASSACRED torn up mesh showing and not safe at all to drive. Replaced immediately with MPS2's and had a four wheel alignment done to the best of the ability of the shop where it was done. Caster was still off. Brakes were installed in the same time frame. Rear brake pads installed.
Been living with it ever since.
NOW I AM A CAR GUY
Late 2011 I install my Tiens, no alignment, but I think I'm safe. (wrong)
Now, December 2012 rolls up and I have been helping my parents with tire choices for their German cars and when they finish getting an alignment, I decide to congratulate my self and say what a good son and technically knowledgeable car enthusiast I am. I mean just look at my PERFECTLY ALIGNED TIRE WITH THE MESH SHOWING AAAAAAAH
290$ and a Michelin Super Sport later I am fed up with this pull to the right and want to get it fixed. Right after this latest tire is put in, I take it to nissan for a 4 wheel alignment. Absolutely no change in the steering behavior and it is confirmed by the technician that it's not just me. Also, the tech says I need a rear left toe arm for complete alignment, because it is bent. (which is weird, since I have never hit my left side.) But my alignment is mostly good. I could buy the part my self, put it in, and have it aligned again, but I want to see what else is wrong before I do this.
Currently, my rear tires are slightly unevenly worn on the inside. (.4 L vs .7 R)
Can't compare front wheels, but the FR is not wearing prematurely as of the last 100 miles.
My guess is that the root problem was from the wreck in 2009 and something else needs to be fixed. Can anyone help me figure out what is going on?
Thanks for your help!
Car Equipment:
Suspension- Tien Basic Coilovers
Brakes- (F) Stoptech (R) Non-Brembo Factory
Wheels- Stock 2004.5 6 spoke round.
Tires- Stock size michelins as follows:
Car has two same aged Michelin Pilot Super Sports in rear. Uneven camber wear
Car has one Michelin Pilot Sport Pro PS2 on the FR. I originally purchased two for the front, but they stopped making the PS2 so I bought --(next tire)
Car has one Michelin Pilot Super Sport on the FL. This wheel was showing the mesh. I blame this on crappy alignment after I put my Tien Basics on. This isn't the problem (or is it?)
Old Jan 4, 2013 | 06:29 AM
ehaalandtluk
For reference, my wreck was worse than this one:
https://my350z.com/forum/maintenance...ts-broken.html
My wheel's orientation was more pronounced, and it also happened in the front.
Old Jan 4, 2013 | 06:31 AM
iideadeyeii's Avatar
iideadeyeii
Only read first few lines, but I had a problem like this and it was due to a loose lower ball joint.
Old Jan 4, 2013 | 06:32 AM
ehaalandtluk
Part number?
Old Jan 4, 2013 | 10:18 AM
pro_350z's Avatar
pro_350z
maybe your frame got bent?
Old Jan 4, 2013 | 10:19 AM
ehaalandtluk
I don't think so. The impact didn't even touch the body of the car, only the wheels/suspension.
Old Jan 4, 2013 | 01:21 PM
zakmartin's Avatar
zakmartin
The 350Z doesn't have a frame - it's unibody.
OP - if the tech told you that you need a left rear toe arm, then you should start there.
