Touch up paint pens?
Old Jan 12, 2013 | 09:36 AM
Tone91's Avatar
Tone91
Default Touch up paint pens?
Okay so I have a 2003 pikes peak white Z and its got some paint chips in the front as well as some other random chips around the car. I've been looking at the paint pens online but they all have 1 side paint and the other clear coat. The thing is pikes peak white (qx1) is a tri-coat so do I need to buy the pen + two bottles of the base and top coat or will the pen by itself still look good?
Old Jan 12, 2013 | 10:14 PM
Waiz's Avatar
Waiz
I did a search for Touch Up and found the following for you:
https://my350z.com/forum/maintenance...int-chips.html
Old Jan 18, 2013 | 12:44 AM
samsniss350z's Avatar
samsniss350z
As i understand it some of these 'magical' touch up pens are only ok if the scratch doesn't go below the clearcoat as the chances of getting a generic white or a generic red is not going to give you a match on your color. The best bet is to get a touch up pen matched specifically to the color of your car. Also don't use the brush supplied with the container, use a cocktail stick to apply the touch up as you tend to put on less paint and have far more control.
Old Jan 18, 2013 | 12:52 AM
SilverStone2003's Avatar
SilverStone2003
I was wondering where I could get a color code matched touched up pen as well. When I was getting fuel I dropped the damn pump nozzle and it put a nick on my fender right by the gas door. I was furious.
Old Jan 18, 2013 | 02:55 AM
bluelineshooter's Avatar
bluelineshooter
I went to the dealership and b!tched about the chips until they gave me the Nissan touch-up product for free. It's two bottles that each have the option of using the pen or the little brush. One is the white base coat and one is the pearl clear coat.
Old Jan 18, 2013 | 05:01 AM
verdict.'s Avatar
verdict.
It won't be a perfect match. I always used the base coat pen only when covering small chips/scratches on my PPW. If I used both the base coat and clear coat pens, it would always dry a few shades darker then my actual paint -- and it was highly noticeable (less noticeable by using base coat only).
Old Apr 4, 2023 | 01:43 AM
MarshaHarrison's Avatar
MarshaHarrison
Many people adore and highly regard POSCA pens and markers. They can be applied to a variety of porous surfaces, including unglazed ceramic, stone, wood, paper, cardboard, metal, and silicone. You can use it in conjunction with a water-based varnish, depending on the surface.
Old Apr 4, 2023 | 09:30 AM
Heel Til I Die's Avatar
Heel Til I Die
I really hope OP hasn't been rolling around with those paint chips for the last decade. That would be madness.
Rev_Night
Nov 7, 2020 06:00 PM
Cashwin
Oct 1, 2015 06:36 AM
