Trunk opens when cars unlocked
Old Jan 24, 2013 | 11:37 AM
Bruno350z's Avatar
Bruno350z
Default Trunk opens when cars unlocked
It's happening to my friends 350z and I can't figure it out.
When you unlock his car (with the key or key fob) it also opens the trunk. (If you use the unlock/lock switch on the doors nothing happens)
Yesterday we were putting gas and as the gas is being pumped the trunk release went on at least 20 times
I read up a bit and it showed either a blown fuse or the bcm reset? So I disconnected the negative terminal for 15 minutes and checked all the fuses, neither worked. And those are the only two suggestions I've found during my research
Any help would be appreciated
Old Jan 25, 2013 | 11:20 AM
qew's Avatar
qew
Sounds like its getting power from somewhere else look at the schematic for the trunk latch motor and trace it down. Like a power source from the door locks is tied onto the trunk latch power supply.Suggest getting a 10 dollar shop factory repair manual cd from eBay has all the info u need.i got mine there.
Old Jan 25, 2013 | 12:14 PM
Jennifer 2's Avatar
Jennifer 2
It could be that the manual release button/switch located just above the rear license plate is sticking in the open position. When you lock the car, power is removed from this switch, effectively locking the trunk. When you unlock the car (with the key or remote key fob) it supplies power to one side of this switch allowing you to open the trunk.
If the spring loaded switch mechanism is sticking/faulty, it will react as you have described.
It’s really hard to diagnose cars over the Internet, but look into this switch and/or the solenoid it controls.
Old Jan 25, 2013 | 02:48 PM
Bruno350z's Avatar
Bruno350z
Thanks i'll look into it and reply with an update
Old Jul 13, 2016 | 07:53 PM
350zsd's Avatar
350zsd
Default Trunk opens when unlock car
Any solutions? My car is now doing this. It keeps opening multiple times til the arm button is pushed.
Old Jul 14, 2016 | 05:58 AM
rancor's Avatar
rancor
It probably would have been better to post a new thread then post twice in very old threads. Bruno hasn't been active since 2013, and it looks like most people in your other thread haven't been active in a few years also.
reno56
Interior
17
Nov 20, 2015 05:21 PM
Ronso
Oct 30, 2015 12:39 PM
cashmoney03
Sep 27, 2015 05:24 PM
PureR3d
Sep 10, 2015 06:23 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
