need new engine advice
Old Feb 9, 2013 | 07:19 PM
Marcodiaz93's Avatar
Marcodiaz93
Default need new engine advice
so i ruined the motor in my 2006 350z manual transmission with ony 64k miles... anyway, i need to know which engines are compatible with my car. i know i need a 25th anniversary or 2006 350z engine but does it have to be off a manual or can it be one off of an automatic? also which g35 engines will fit my car? it would be nice to fit an hr in there but i dont really want to modify anything to make it fit. also what price range should i pay for one around the same mileage as my old one? and what should i look out for?
Old Feb 9, 2013 | 08:57 PM
350z006's Avatar
350z006
If you truly have a 2006 manual engine, it's called a "Revup" engine...it was only offered in the 2005 anniversary model and 2006 year for the 350z; it was also found in the G35 for the 2006 year, I believe...and it only comes from manual transmission cars.
It looks significantly different from the standard DE engine (front engine cover), and unfortunately for you is not as common as the standard DE engine either, since it was only offered for a very limited time; I would know since I have a Revup myself...
Good luck finding one; if you are having trouble consider getting a shortblock/longblock from one of the dealers on the forum...or if you know a good VQ mechanic you can get it rebuilt cheaper than the dealer, but I don't know if you'll find any VQ specialists in Modesto...
Old Feb 9, 2013 | 09:01 PM
Marcodiaz93
yea i have not been able to find a mechanic here in modesto at all. so the revups didnt come in automatics? damn im going to have a hard time finding one. is 2800 too much for one with 40k?
Old Feb 9, 2013 | 09:05 PM
Slyguy_38's Avatar
Slyguy_38
I have an 06 and a RevUp motor with 47K miles. I've only had it a few weeks and I'm watching for the dreaded oil consumption problem. What happened with your motor?
Old Feb 9, 2013 | 09:10 PM
Marcodiaz93
yea i was lucky that mine didnt have the oil consumption issue and thats what im scared of if i buy a used one that it will have that problem. i was installing my finally purchased mrev2 and i think while i was putting everything back together, something fell into an intake port and bent some valves or possibly cracked the piston crown. im gonna pull the engine out soon and see what all happened but most likely i need a new motor lol/ it sucks. i had my car for about 5 months. i babied that thing.
Old Feb 9, 2013 | 09:35 PM
faiz23's Avatar
faiz23
FEZZZZZZ
If it ain't broke than don't fix it. Now that you broke it lets try to fix it. Look on local
www.car-part.com
www.copart.com
ebay
craigslist
https://my350z.com/forum/engine/5107...ur-engine.html
http://www.importpartspro.com/shblpa.html
Rev-up: 2005-2006 G35 Sedan 6mt Manual & 2005-2007 G35 Coupe 6mt Manual. 2005 35th anniversary edition manual 6mt 350z and 2006 manual 6mt 350z.
Engine packages are customizable to match your goals. Here are two samples of common configurations:
Stage 1 Short Block packages start at $2765 and include CP Pistons, Eagle Rods, ACL Bearings, machining, align hone, balance, blueprint and pro assembly!
Stage 1 Long Block packages start at $3690 and include the Stage1 Short Block, ARP L19 Head Studs, ARP Main Studs, Cometic Head Gaskets, Mill & Clean Heads and assembly.
Revup with painted timing covers
REV UP ENGINE
NON REV UP ENGINE
Old Feb 10, 2013 | 06:02 PM
DFW Adrenaline's Avatar
DFW Adrenaline
You might want to also check out 123engines.com
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
