Is it okay if I change my coolant and don't start car for few weeks
Old Mar 1, 2013 | 09:30 AM
Pholicious's Avatar
Pholicious
Default Is it okay if I change my coolant and don't start car for few weeks
Is it okay if I drain my coolant to change my hoses then fill rad back up but don't start the car for a few weeks?
Old Mar 1, 2013 | 09:59 AM
Junkster's Avatar
Junkster
why would it NOT be ok?? lol
Old Mar 1, 2013 | 10:23 AM
zakmartin's Avatar
zakmartin
For the sake of inhibiting rust, I'd say you should cycle the coolant and burp the cooling system before letting the car sit for a long period of time. Otherwise, go ahead and fill what you can with a 50/50 solution (something's better than nothing) and when you're ready to start the car again, run a radiator flush treatment (i.e., Prestone Flush -n- Fill) through the system, then rinse and refill. If you don't use pre-mixed coolant when you refill, be sure to use distilled water with the new coolant. That should get rid of any surface rust or contamination that accrues on the engine surfaces that aren't protected by the rust inhibitors in the coolant while the car's just sitting there.
Old Mar 1, 2013 | 10:32 AM
Tracktimeplz's Avatar
Tracktimeplz
+1
water droplets that are inside the engine/waterpump/ect that get exposed to open air for a prolonged period, may lead to corrosion.
Old Mar 1, 2013 | 10:49 AM
Pholicious's Avatar
Pholicious
Thank you, Ill do that.
Chris350z03
Oct 8, 2023 07:19 PM
etkms
Jun 19, 2022 06:30 PM
allmycarsdie
May 13, 2016 04:38 PM
smithmt3
Sep 11, 2015 08:25 PM
Mw870
Sep 10, 2015 07:50 PM
