Catalytic Converter Clicking
Old Mar 11, 2013 | 10:29 AM
DemandedAce's Avatar
DemandedAce
Default Catalytic Converter Clicking
There is a clicking sound from my driver side cat, I'm thinking there is either a tiny puncture or the shield around it is tapping. Would removing the shield to test the theory be a terrible idea and risk major damage to the cat?
Old Mar 11, 2013 | 01:44 PM
DavesZ#3's Avatar
DavesZ#3
that's normal - it's the heat shield expanding and contracting around the cat.
Old Mar 12, 2013 | 06:54 AM
DemandedAce
Are you sure? It's fairly audible especially when with barriers on the side of the car and it only is coming from the driver side
Old Mar 12, 2013 | 07:55 AM
Bret86944's Avatar
Bret86944
How in the world do you know it's the catalytic converter if it happens while driving?
Old Mar 12, 2013 | 08:12 AM
DemandedAce
You can hear the ticking while the car is stationary and running, it just increases in frequency of the ticks with applied throttle
Old Mar 12, 2013 | 09:51 AM
Bret86944's Avatar
Bret86944
Since there are no moving parts associated with the catalytic converter, the closest thing that could be making noise is the heat shield, if it is broken. It will vibrate more at certain frequencies (probably 3k rpms or so). Otherwise it's something nearby that just sounds like it's coming from that area.
Is it a rattle? A metal dinging? I'm just looking for more clues.
Old Mar 12, 2013 | 09:56 AM
DemandedAce
It's like a quick click or tick, I'd most liken it to the sound of a small puncture letting air puff out (though I hope that's not the case, I fear it is). I'll try to upload a recording of it
Old Mar 12, 2013 | 02:36 PM
Action Bill's Avatar
Action Bill
Are you sure its not your throw out bearing?
Old Mar 13, 2013 | 06:11 AM
DemandedAce
O_o my hoogiemacallit?
Haha sorry, so I Googled what that is and is that in automatic trans? Also, it is consistently ticking whether in park, idling, or moving and it increases in frequency with throttle application.
Old Mar 13, 2013 | 04:28 PM
Action Bill
Ohh lol no auto trans do not have a throw out bearing, it could be your heat shield or it could be a million other things. I see you have a rev up z so I'd make sure your oil level was good then just take it to some one and let them figure it out. I think just assessments are like 50 bucks these days.
Old Mar 14, 2013 | 08:33 AM
DemandedAce
Funny you mention my oil level, it does appear to have a minor leak as I do have to add oil more often than I'd like. I thought that the oil consumption issue was just in the manual though? What would the association be here?
Thanks for all the advice so far btw!
Old Mar 14, 2013 | 08:39 AM
DemandedAce
Are you saying it could possibly be the oil leaking into the cat and burning off and that could be the ticking? How would I be able to test that if so?
Old Mar 14, 2013 | 02:37 PM
Action Bill
Id think if your oil was low, depending on how low, the valves could be tapping and that could very likely be the source of the sound. Id top the oil off let her run at idol and see if it quites up at all. I doubt oil leaking on the cat is causing tapping because the noise increase with revs. also run the car with the hood up and listen to the noise see if you can pin point it better.
sales@czp
Sep 23, 2019 03:30 PM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
Fixxxercask
Interior
Oct 6, 2015 10:17 AM
