Throttle issues help
Old Mar 14, 2013 | 12:53 PM
Sebascaris's Avatar
Sebascaris
Default Throttle issues help
Hi everyone,
I’m having some issues passing emissions test, i need to set the car to 2500rpm for them to test it but my pedal is wayyy tooo sensitive and I can’t make it stay at 2500, it jumps up and down and I’m barely touching the pedal itself. I can press the pedal less than a cm in and it will go all the way to 5000rpm-ish.
I have an aem fic installed and I checked the voltage of the tps and it moves a lot even if I try holding the pedal still, the tps showed fine from 0% to a 100% but then I did the throttle reset (ign 2 secs, off 10, on 2 off 10) and now the fic won’t even detect my throttle, not even calibrating.
Any ideas why the aem won’t detect my throttle anymore? And also is there a way of making the throttle less sensitive?
Thanks!
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
