Is my oil pressure low?
Old Mar 19, 2013 | 08:59 AM
masphx's Avatar
masphx
Default Is my oil pressure low?
This is at idle in my 2008 350z base model...
Old Mar 19, 2013 | 09:16 AM
TPete19's Avatar
TPete19
Please search. This is an extremely common question and has been answered many times.
Old Mar 19, 2013 | 09:45 AM
Deteria's Avatar
Deteria
Very low. Is that startup idle?
Mine idles above half way mark (60-70psi) after engine has been on for some time. Initial startup idle is around 90psi.
Old Mar 19, 2013 | 09:57 AM
HK350 Z's Avatar
HK350 Z
I have a 2008 and it has idled arouind 10-15psi after warming up,that looks normal to me if thats after the engine is warm.
Old Mar 19, 2013 | 10:18 AM
redline06's Avatar
redline06
shiieeettt mine is lower than that at idle when the engine is up to temp, youre fine
Old Mar 19, 2013 | 10:20 AM
redline06's Avatar
redline06
Thats way too high my friend
Old Mar 19, 2013 | 10:35 AM
andrew's 350Z's Avatar
andrew's 350Z
Start up im around 80-90psi. After warm up at idle its right around 20psi. Cruising the freeway at about 70mph its around 60psihave an 04btw.
Looks like its fine.
Old Mar 19, 2013 | 10:43 AM
masphx's Avatar
masphx
Here is what it was idling at. This is after a 20 mi drive on the freeway in 80 degree AZ weather this morning...
Old Mar 19, 2013 | 10:49 AM
redline06's Avatar
redline06
At operating temp oil pressure should be 14psi at idle and 43psi at 2K rpm (no load), on an HR that is
Old Mar 19, 2013 | 11:51 AM
winchman's Avatar
winchman
^^ That's the minimums. More is better. Mine runs 30 at idle and 60 at 2K when fully warmed up. I'm using Pennzoil Ultra 5W-30.
Old Mar 19, 2013 | 01:08 PM
jc21's Avatar
jc21
I have an '03 and mine is about the same during idle, and that is when the motor is fully warmed up as well. Initial cold start up it'll be about 80 psi give or take, and then during warm temps when the motor is all good and warmed my oil pressure sits about the same as yours. Im using Pennziol Platinum 5w-30, but im switching to castrol full synthetic
well all in all I say that yours is in normal condition.
Old Mar 19, 2013 | 01:10 PM
JERZ350's Avatar
JERZ350
That's normal idle pressure when warmed up operating temp. Cold start idle will be anywhere from 70-90psi and continue to fall as it warms.
Old Mar 19, 2013 | 01:20 PM
masphx's Avatar
masphx
Thanks for all the responses. Been using Mobil-1 5w-30 synthetic for the last three or four oil changes.
Old Mar 19, 2013 | 02:21 PM
laurentj23's Avatar
laurentj23
Did you check the oil?
Old Mar 19, 2013 | 02:37 PM
350zsunshinefl's Avatar
350zsunshinefl
switch to amsoil, will work wonders on oil pressure
Old Mar 19, 2013 | 04:18 PM
Darkside Mojo's Avatar
Darkside Mojo
Holy god! 80 degrees iin the morning?!? screw it, i'm moving there.
Old Mar 19, 2013 | 04:25 PM
jerryd87's Avatar
jerryd87
not really, not going to have any issues, cold start mine is over 120 psi and hot idle is 60 psi although i have deleted the squirters
Old Mar 19, 2013 | 07:23 PM
Carter86's Avatar
Carter86
Im having the same issue here. I just replaced my oil pressure sending unit also.
I did an ECU reset yesterday and it seems like idles low and the PSI is very close to 0.
I checked the oil level and its fine. I did oil change replaced my oil pressure sending unit at the same time about 400 miles ago. I did search and found nothing.
Mine is 04.5 VQ35DE Non rev up
Old Mar 19, 2013 | 07:47 PM
HK350 Z's Avatar
HK350 Z
I use the same and have been the last 70K miles I have put on the HR.
Old Mar 19, 2013 | 07:50 PM
jc21's Avatar
jc21
I agree with redline06, for some reason I find yours to be too high as well. i think 120 psi on cold start is not common at all. My cold start is at around 70-90 psi and my normal temp idle is about the same as op's oil pressure.
