where to get rear wheel hub assembly???
Old Mar 24, 2013 | 08:45 AM
adelort's Avatar
adelort
Default where to get rear wheel hub assembly???
Hey guys... i just removed my rear wheel hub assembly and the outside part with the lug nut studs is shot... need a new one. The problem being is that all the local parts stores only sell the wheel bearing by itself... they sell an "assembly" with both the wheel bearing and the hub pressed together for the front only, but not the rear...
does anyone know where to get the assembly for the rear? Ive called autozone, napa, advance auto, orielly and no one can get it. Is it a factory OEM part only?
any help would be appreciated.
Old Mar 24, 2013 | 07:01 PM
RENFRO's Avatar
RENFRO
You won't be able to get the bearing and hub assembly together for the rear like you did the front. Also, as far as I know the hub assembly with the studs is a dealer only part. You might as well get a set of good wheel bearings while you're at it since you'll have to have them pressed onto the new hubs anyway.
350Z_Al
Oct 29, 2020 07:44 PM
samansharif
Sep 25, 2015 12:31 PM
