Window Motor
Old Apr 12, 2013 | 06:35 PM
geomark's Avatar
geomark
Default Window Motor
If I press the window up button for the window and it goes up then a quarter way down, does it mean the motor needs to be replaced or can it be fixed with a reset?
Old Apr 12, 2013 | 10:52 PM
aboveliquidice's Avatar
aboveliquidice
Two scenarios...
Most likely: needs a reset. Both this site and YouTube have walk throughs on how to do this.
Possible: the motor is struggling to overcome resistance on the way up. When this happens, the motor thinks it has hit an object, and rolls back to prevent damage to motor/window. In this case, the motor is usually worn, and heading towards replacement.
Your scenario sounds like the former, just going by loose description.
Old Apr 14, 2013 | 07:16 PM
YardieXplorer's Avatar
YardieXplorer
geomark... I have had the same situation. The previous recommendation is spot on. That being said, a reset will last maybe 2 weeks then it reverts back to rolling back down. That is good to hold you until you get a new one. But yes there are tutorials on resetting it. I have used the one on YouTube. Good luck man
Old Apr 14, 2013 | 08:13 PM
ksuberk54's Avatar
ksuberk54
A reset should help but I think it's more the switch than the motor. It's happening to me right now so I know what you're going through.
Old Apr 16, 2013 | 06:25 AM
Speedypat95's Avatar
Speedypat95
I would say definitely try a reset first, but the same thing happened to me and I replaced the motor and it works perfectly fine now.
Fixxxercask
Nov 9, 2015 11:10 AM
