Missfireing
Old Apr 18, 2013 | 04:40 PM
Supertouring's Avatar
Supertouring
Default Missfireing
I have a check egine light on. I got it check and the computer said that number 6 cylinder was missfireing. I went out and bought a coil and a spark plug. Nothing happend. I have not done a tune up since last spring. I have only put about 1500hrs miles last year, I do not think it's the plugs. The only other thing I can think is trying to clean the fuel system or something. Also the air filter is fine. Any idea folks?
Old Apr 18, 2013 | 06:52 PM
Tylermarks's Avatar
Tylermarks
by nothing changed do you mean your engine light is still on? if so did you clear your ecu of fault codes?
Old Apr 19, 2013 | 01:34 AM
nachospizza's Avatar
nachospizza
How come cylinder number 6 always mis-fire? Happened to me too and it was a bad coilpad.... I change that and also the coil harness also! Fix the problem but why always number 6????
Old Apr 19, 2013 | 05:04 AM
sradenton's Avatar
sradenton
Did you check for oil in the spark plug tube? leaky seal
Old Apr 19, 2013 | 07:05 AM
Supertouring
Did not chage the coil harnes. I did change the coil pad, the plug and it was dry.
I'll have to try the coil harness then. I did not set the ECU fault code, could that be it?
Old Apr 19, 2013 | 07:22 AM
iideadeyeii's Avatar
iideadeyeii
Diagnose the problem and stop just throwing parts at it.
Saifzaki
Jul 26, 2015 05:05 PM
RWDXTACY
Mar 16, 2009 07:05 PM
sam-z
Jun 4, 2007 08:53 AM
backagain
Aug 19, 2005 07:30 AM
AceJ587
Jul 2, 2004 07:36 PM
