04 350z passenger window problem.
Old May 23, 2013 | 01:06 PM
chue350z's Avatar
chue350z
Default 04 350z passenger window problem.
hi i need help figuring out what it could be before i take it apart.
The problem is when the passenger window is down (any position except closed) later when i tried to close the window it doesnt go up.But when i push down on the window and it you feel it goes down like 1/8in and then when i press the up button the window works again. If i continuously press up and down on the button it works so it varies on an amount of time before it doesnt work maybe like 10min it keeps doing that so im not sure if maybe something needs to be adjusted or i have to replace the whole motor and regulator.
thank you
Old May 26, 2013 | 01:22 PM
go-part's Avatar
go-part
Vendor - Former Vendor
Best thing to do would be taking the cover off the inside of the door and make sure all the wires are connected properly. Then see if the motor needs to be replaced.
Old May 26, 2013 | 01:30 PM
bmyles's Avatar
bmyles
Might have to do this: https://my350z.com/forum/maintenance...-be-fixed.html
Old May 30, 2013 | 09:59 PM
chue350z's Avatar
chue350z
thanks i will try that out
Old Jun 1, 2013 | 05:22 AM
chue350z's Avatar
chue350z
well looks like my motor is going out.... gotta replace it or repair it
thanks for the help
Siqcology
Sep 18, 2019 01:45 PM
reno56
Interior
17
Nov 20, 2015 05:21 PM
CJs_Z33
Sep 18, 2015 12:06 PM
AP350z223
Sep 8, 2015 04:38 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
