Bad vibration at 35-40mph
Old Jun 3, 2013 | 10:33 PM
Bpb713's Avatar
Bpb713
Newbie
Default Bad vibration at 35-40mph
I've searched a while now and found a couple people with a similar issue but no results.. Okay so my 05 touring 6mt has had a decent vibration over the last few months.. Didn't pay a whole lot of attention to it ASSUMING is was just some warped front rotors.. Okay so over the last few days it has gotten progressively Worse!! I replaced rotors only to find this wasn't my issue at all.. Put the car on lift and went thru the gears and every time it would start making the horrible vibration around 35-40mph... Vibrates at any speed but worst there. I felt my drive shaft and doesn't seem like any out of the ordinary play in it. The shifter bounces and the whole car shakes. I don't believe it would be my flywheel since it still vibrates even with the clutch in or in neutral at these speeds. Anyone have an answer for this yet?
Old Jun 3, 2013 | 10:42 PM
Bpb713's Avatar
Bpb713
Newbie
*Note* I know this isn't an issue w my tires/wheels cause I've ran 3 different sets and no change what so ever.. Currently have my 3pc oz racing wheels w brand new tires on them.
Old Jun 3, 2013 | 11:18 PM
naonran's Avatar
naonran
it is aglobal issue.
Old Jun 3, 2013 | 11:59 PM
Bpb713's Avatar
Bpb713
Newbie
"Aglobal"??
Old Jun 4, 2013 | 05:47 AM
bstingZ's Avatar
bstingZ
my past experiences with many cars I own, it point to driveshaft ujoin. even the slice of movement will cause it to vibrate. hope this help.
Old Jun 4, 2013 | 09:32 AM
Bpb713's Avatar
Bpb713
Newbie
Thank you bsting.. Another note the vibration changes while going around curves or even barely steering the wheels.. I know this isn't a wheel bearing or anything in the front because I still get the awful vibration while the car is going 45 mph on a lift
Old Jun 4, 2013 | 09:57 AM
04.350z's Avatar
04.350z
Check drive shaft u joints and if they check out I'd look deeper into the differential
Old Jun 4, 2013 | 06:59 PM
Bpb713's Avatar
Bpb713
Newbie
Thanks but its not the diff.. I can see the tranny and drive shaft shaking, just can't see what's causing it.. Whatever it is I'm 99% sure it's somewhere near where the drive shaft meets the tranny. Note I have solid rear diff bushings.. Maybe these caused my issue? They've always caused the rear end to whine a little since install but so has everyone else that put these in
Old Jun 5, 2013 | 08:54 PM
Bpb713's Avatar
Bpb713
Newbie
Possibly a rear wheel bearing? I jacked the car up but neither wheel had any play in them.. I don't suppose they will always have play tho.. Anyway do you guys think that's a good possibility? That would explain why the vibration changes a little when steering thru curves.. While turning left I get less vibration and when turning right I get more vibration, or vise versa. I know you guys can't help a whole lot without actually driving or looking at the car. I just don't wanna go replacing tons of stuff that doesnt even need changing trying to figure out my issue
Old Jun 6, 2013 | 05:47 AM
bstingZ's Avatar
bstingZ
last year my bro's Supra have similar issue like your, he didn't listen to my advice and did all the possibility he and his friend can think off without telling me. Finally came back to me, the Ujoin cost $69 and it did the job vs he spend close to a 1k. Take it to some local machenic you know and trust for recommendation. good luck. let us know.
Old Jun 6, 2013 | 05:57 AM
bstingZ's Avatar
bstingZ
wheel bearing issue only give you a lound Woutzing sound, the faster you go the lounder the sound. I am pretty sure is you shaft Ujoin.
Old Jun 6, 2013 | 08:09 PM
Bpb713's Avatar
Bpb713
Newbie
Alright well I talked to a local tranny shop with a great reputation and he told me that if it is the u joint not to replace them but to buy a whole new driveshaft.. He said he's had bad experiences with them in the past and after replacing the u joint the issue only gets worse... Said something about the way Nissan designed it was a bad design for replacing the ujoint.. He said he's also ran into the same issue with other Nissan models.. I know he isn't just tellin me that expecting to get paid more bc he is a family friend and knows that I would do the work myself anyway. Have any of you guys ever replaced the u joint on a z?
Old Jun 6, 2013 | 08:24 PM
mattleegee's Avatar
mattleegee
for fun check if the axle nut it tight on both rears
Old Jun 7, 2013 | 01:21 PM
04.350z's Avatar
04.350z
Sounds like he wants to do a easy job vs a mildly harder one
Old Jun 8, 2013 | 10:42 AM
bstingZ's Avatar
bstingZ
2nd.
check out youtube, there should be something about replacing ujoint.
Old Jun 8, 2013 | 12:30 PM
323_z33's Avatar
323_z33
Maybe balance rims when they are unbalanced at that speed it shakes like tickle me Elmo
Old Jun 8, 2013 | 03:54 PM
bjr's Avatar
bjr
I locked in on that comment and am wondering if it is possible that you need to replace your rubber transmission mount?
When you did solid diff bushings you made all 3 solid right???
Old Jun 9, 2013 | 08:03 AM
04.350z's Avatar
04.350z
Not bashing but I used to be a auto technician.
And replacing the drive shaft usually pays about 2.0 and takes about 1.3
Replacing the u joint pays about 2.3 and takes closer to 3 ...
At least that's what is was on tundra trucks
But could be wrong
Old Oct 22, 2020 | 02:52 PM
Kerry Fordyce's Avatar
Kerry Fordyce
Ok let me save you a lot of time and money. Same problem I have replaced all wheel bearings had custom driveline built all bushings and mounts are good .disconnected half shafts ran car on lift still feel vibration only thing left is rear end looks like I'm diving in to the rear end
Old Oct 22, 2020 | 03:09 PM
Emski's Avatar
Emski
IT'S BEEN 7 YEARS. Maybe if you answered in 2013 holy cow.
