slave cylinder bolts, size needed
alright so I've been searching for a while now but can only come up with the part number from courtesy but can't find the thread pitch or diameter or anything. it's the two bolts that bolt the slave onto the trans (04) that I need to replace. the number from courtesy is 081568301E] BOLT-HEX,P.
basically what happened is the holes that they go into on the trans are stripped enough to hold them in but not tight to my slave cylinder is kind of loose. I was just going to put in helicoils and be done with it but want to make sure I got the right size.
thank you all
thank you all
never mind I got it, for anyone who needs it and can't find it, it is m8 1.25x whatever if you get longer ones you can cut/grind them down. I got lucky and had one barely hanging in there when I got home
Subarism
East Canada
Sep 23, 2015 06:09 PM
hardkicks
Sep 20, 2015 12:28 PM
