350Z Oil Change
Old Jan 25, 2004 | 05:30 PM
overZealous's Avatar
overZealous
Default 350Z Oil Change
I'm not a good technical writer but anyone with a digital camera and a computer can pretend these days so here is my interpretation of the 350Z oil change process. I'm sure there are errors and omissions so point them out and I'll fix whatever is wrong.
Thanks,
MWeber
What you'll need:
5 quarts motor oil of your choice (I use Castrol Syntec 5W50)
1 oil filter of choice (I use stock Nissan filters)
1 copper oil drain plug washer
Oil filter wrench
14mm box wrench or socket (for drain plug)
10mm socket (box wrench works if you want to spend an extra
30 minutes removing and reinstalling the plastic under engine bay cover).
floor jack and jack stands, ramps or some other means to lift the vehicle.
The car should run until normal operating temperature is
achieved before changing the oil. Not sure why. I think
it is so the mechanic can obtain the worst possible burns
on his or her hands while removing the drain plug and the
filter. In any case, having done this, I use a floor jack which
doesn't quite fit under the car so I drive it up on a couple of
2X4's as shown. If you are using ramps then disregard the
next few frames.
Slide the floor jack under the vehicle and lift as shown.
The front lift point is behind the motor on the crossmember
as shown.
Here's another view.
If I am just changing the oil, I don't normally use jack stands
but in this case I was doing some other work so I did. Safety
would dictate that you use them any time you are working under
the car (again assuming that you are not using ramps). I placed
mine on either side of the front suspension crossmember as
shown. Note that my jack stands are not in the factory
recommended locations. I don't have the proper pads to
prevent my rocker panel area from being damaged by the
stands placed in those locations.
Next you'll need to remove the under engine bay cover. Note
that it had already been removed in the previous 2 frames.
It is attached with 14 10mm bolts and 1 plastic push clip
(My platic clip mysteriously disappeared after the second oil
change).
Here is the cover once removed from the vehicle.
Having removed the cover, you are now ready to open
up the drain plug and remove the filter. I use a 14mm
socket and a strap wrench respectively. I am assuming at
this point that you have a suitable container to drain the oil
into. Please dispose of waste oil properly. Many auto stores
will take waste oil at no charge.
Here's a shot with the drain plug and the filter removed.
Make sure the motor has completely drained and
clean up the oil filter attachment flange, which is actually
an oil cooler, and the oil pan around the area of drain plug
before installing either.
Make sure you replace the copper washer on the oil drain plug
before reinstalling. It is made to completely collapse upon
installation and may leak if reused.
I like to partially fill the new filter with oil before installing.
I suppose the oil pump gets less of a gulp of air upon initial
start-up but I doubt that it makes a difference. In this case the
oil filter is mounted horizontally so don't fill it up more than half way.
Always lubricate the oil filter gasket with fresh motor oil
before installing.
Reinstall the filter and the drain plug. Turn the filter until it
makes contact with the flange and then turn it, by hand, an
additional 3/4 turns. Don't over tighten either the filter or the
drain bolt. It should look like this. If it doesn't, have another
beer and go back to step one.
Now refill the crankcase with 5 quarts of fresh motor oil (less
whatever you initially poured into the filter if any).
You can now run the motor a bit to pump that oil all the way
through. If you have the front end jacked up much higher than
the rear, you may want to wait until its down off the jackstands
before checking the oil level. Do check for any leaks before you
replace the engine bay cover. Assuming you have no leaks,
reattach the cover.
Now do whatever you did to get your vehicle up on the jack
stands, ramps, etc. in reverse order. In my case that meant
jacking it back up with the floor jack, removing the jack stands
and reinserting the 2X4's under the wheels. Otherwise I would
not be able to get my floor jack back out from under the car.
Allow enough time after having run the motor for all of the oil
to drain back into the crankcase before making a final oil level
check. Good luck with that exclusive Nissan excuse for a dip stick.
My final reading is never more than half way between the
marks even though I add a full 5 quarts. The manual does say
"approximately".
Old Jan 25, 2004 | 06:10 PM
zand02max's Avatar
zand02max
Great Post. Now here is my dilemma, maybe you can help me out.
I did my first oil change and did not know you had to take the damn plastic cover off to get the filter off. Well needless to say, I poked a hole in the oil filter with a screwdriver to get it off. Took me about an hour to finally get the OEM filter off. Anyway the rings that the filter screws onto, well I chipped one of those when I tapped my screwdriver in to get the oil filter off.
My question, is, do I need to replace the rings that the filter goes into, or leave it alone. The new filter fit fine and I have no oil leakage.
Any helpful info will be helpful, thanks
Heres the pic I was talking about
Old Jan 25, 2004 | 06:23 PM
overZealous
Not sure what you mean by "rings". You mean you chipped one of the threads on the flange? If you just chipped one of the threads AND the screw driver did not go all the way through the threaded protrusion and the new filter screwed on ok, I don't see a problem. If you went all the way through though, that would act as a filter bypass which would not be good. Please define "rings".
Old Jan 25, 2004 | 06:31 PM
zand02max's Avatar
zand02max
The rings that the filter screws into. I chipped a piece of the ring off.
The ring is where you screw the filter onto, hope this helps
The filter still screwed on though.
Old Jan 25, 2004 | 06:36 PM
zand02max's Avatar
zand02max
Heres the pic with the arrows
Also, should I change my plug or just the washer each time I do an oil change?
Old Jan 25, 2004 | 06:39 PM
zand02max's Avatar
zand02max
The only thing the screwdriver did, is chip a piece of the ring, it did not go through the entire assembly.
I just don't want any metal shavings in my engine, and I am wondering if I can just replace the oil filter ring? I am only missing a small piece of the ring, you can barely see a piece was chipped.
Old Jan 25, 2004 | 06:44 PM
overZealous
I wouldn't worry about the chipped thread if the filter still screws on easily. As long as there is not a hole in the flange that shouldn't be there. Just change the washer not the bolt. They are like 5 cents each at your dealer. Last time I bought a filter at the dealer it was only 6 bucks so I just use the OEM filters since I have to go there to get washers anyway. You probably could reuse the washer too if you had to. Or you could switch to a solid copper washer that could be reused over and over. I hope you bought an oil filter wrench. I've been there done that with the poking of the screw driver through the oil filter by the way. LOL.
Old Jan 25, 2004 | 06:59 PM
zand02max's Avatar
zand02max
Yeah, I hate that screwdriver method, but it was the only way to pry the SUPERGLUED OEM filter off.
Yes I have a filter wrench, but since I din't know about the plastic cover, I am sure the filter tool will work now.
Old Jan 26, 2004 | 08:50 AM
Z'd's Avatar
Z'd
If you take out all the bolts and leave the plastic pushclip in place, you can actually pivot the lower engine bay shield out of the way. This makes the process fairly easy, as you just pivot it back and it is already in position for reinstalling the bolts.
Actually, if you switch to a filter like a K&N, which has a 1" socket mount on the end of the filter, you can drop out about 3 bolts, bend the cover down slightly and change the filter.
Old Jan 28, 2004 | 10:46 PM
scubasteve's Avatar
scubasteve
[QUOTE]Originally posted by zand02max
[B]Yeah, I hate that screwdriver method, but it was the only way to pry the SUPERGLUED OEM filter off.
OEM Filters are almost always impossible to remove when it is the car's FIRST oil change. I have crushed many with jsut about every tool made to remove oil filters. Just be thankful you don't have the old 80's Nissan Maxima.....I still have scars from those cars. I dreaded them in the summer!!! I would not recommend the screwdriver method because filter often tears and then you're stuck with the base of a filter superglued to the engine! Never done it, but I've heard horror stories. I think that the band wrenches work the best....make sure that you get the band close to the base to maximize grip, however.
Old Jan 30, 2004 | 05:34 PM
corsair's Avatar
corsair
[QUOTE]Originally posted by scubasteve
[B]
I hear they are making those factory robots alot tougher these days
Old Jan 30, 2004 | 05:42 PM
corsair's Avatar
corsair
jack points
Old Jan 30, 2004 | 06:42 PM
scubasteve's Avatar
scubasteve
It's a conspiracy against us all!!!
Old Jan 30, 2004 | 08:24 PM
350ed's Avatar
350ed
Professional
I had to use a pipe wrench to get it off. Strap wrench did nothing. Made a hole in the old filter but don't matter.
Old Jan 30, 2004 | 09:21 PM
scubasteve's Avatar
scubasteve
some strap wrenches couldn't remove the lid from a peanut butter jar.......I have a nice one that can even have a long 3/8 extension inserted to turn it from the side....but a pipe wrench!!You might want to jsut change the threaded bolt for cheap insurance.
Old Jan 31, 2004 | 01:14 AM
yobri's Avatar
yobri
Broke my strap wrench on the first Z oil change... always fine before. Took me three holes in the filter, and the whole right side of my body soaked in motor oil.
Old Jan 31, 2004 | 01:20 AM
yobri's Avatar
yobri
edit.
Something quirky happened here... now there are three identical posts...
yobri's Avatar
yobri
again...
Old Feb 2, 2004 | 04:32 PM
nyfm's Avatar
nyfm
Somebody sticky this!
Old Feb 10, 2004 | 02:08 PM
zuddenly's Avatar
zuddenly
where do you get those safety stand adapters??? anyone have em?
