Passenger Side Window Auto-Seal problem
Hey Guys
Im having a slight problem with my passenger side window. This is what I have do to replicate the problem:
While I am outside the car, I unlock the doors, and open the passenger side door (at this point, window is rolled all the way up). When I shut the door, the window does not auto-seal once the door is shut. I then open the door again, and press down on the top of the window. This moves the window down about 1" - 1 1/2". I then shut the door, go to the drivers side, and place the key in the lock and turn key to the right and hold it. This will cause the window on the passenger side to roll up.
Has anyone else had this same issue where the window will not auto-seal?
So it stopped working after I used the window reset swtich in the door panel. However, I then got back in the car and held both window switches up (not to the auto position) for about 7-8 seconds, and I heard a click in both, so Im assuming that fixed something, and it is now working again!
