P0345 Cam Pos Sensor code keeps coming back
Old Aug 23, 2013 | 08:49 AM
ericjackson's Avatar
ericjackson
Default P0345 Cam Pos Sensor code keeps coming back
Ok I got this code, at the same time, it became hard to crank the car. takes a couple seconds longer while turning over. I replaced the sensor last night, cleared the code and it cranked fine. I got up this morning and drove my z to work and it did fine. I went out for lunch and it cranked right up but then died. then it took a few tries to crank, but the code was back. Now its back to taking 4-5 seconds to start. Any ideas? What are the chances that the sensor was bad from autozone? Could it be something else? I had another code for the heater 02 sensor or whatever as well this time. the one in the header on that same side. could it be an electrical problem?
Old Aug 23, 2013 | 08:51 AM
travlee's Avatar
travlee
Master
there are 2 cam shaft sensors.... maybe the other one is toast
Old Aug 23, 2013 | 08:52 AM
ericjackson
but the code is for bank 2 (passenger). would that make sense that it is the other side?
Old Aug 23, 2013 | 09:15 AM
ericjackson
I just found out i was totally wrong, i need the drivers side sensor. not the passenger
Siqcology
Sep 18, 2019 01:45 PM
chief3630
Feb 29, 2016 02:54 PM
AbyteZero
Sep 22, 2015 09:17 AM
Dust
Sep 15, 2015 02:08 PM
Dust
Sep 15, 2015 08:28 AM
