Need Help With C1130 and P0345 Codes
Old Aug 23, 2013 | 05:28 PM
chinkymrsettles's Avatar
chinkymrsettles
Default Need Help With C1130 and P0345 Codes
Hey guys i could use some help with this. I was driving and noticed a loss of power, right away the ses, vdc off, slip lights all turned on. It would take 4 seconds to start up after this. I pulled the codes and P0345 cam position sensor bank 2, C1130 abs come up.
I have been reading up on this issue and i purchased a new cam position sensor hoping that would fix the issue. Once i installed the sensor the car started right up with the vdc off, slip lights off. The ses light stayed on so i went and cleared the codes.
After this i drove around thinking the issue was resolved... 10 minutes later my car stalls and all of the lights are back on. I checked the wiring harness and it doesnt seem damaged. Has anyone had this same problem? Ive seen a bunch of threads say maybe i should replace the other sensor and the crank sensor.
What do you think?
Old Aug 23, 2013 | 05:56 PM
chinkymrsettles
Mods can you move this to Maintenance & Repair? Sorry i wasnt paying attention.
Old Aug 24, 2013 | 07:03 AM
SlowCoupe's Avatar
SlowCoupe
Which side did you change?
Old Aug 24, 2013 | 09:40 AM
djamps's Avatar
djamps
Was it raining that day or the day before?
Old Aug 24, 2013 | 10:17 AM
chinkymrsettles
I replaced the drivers side.
it was not raining the day it happened. I was installing my subs if that may have something to do with it.
Old Sep 7, 2013 | 10:36 AM
chinkymrsettles
Replaced the other cam sensor and poof problem solved.
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Detailed Image
Sep 11, 2015 04:35 AM
