Bad transmission mount?
Old Aug 30, 2013 | 09:14 AM
Jbakes727's Avatar
Jbakes727
Default Bad transmission mount?
Hey guys I have a 2004 Enthusiast MT with 88k. Recently at idle I have noticed a vibrating noise in the cabin. When I listen for it, the sound is coming from directly under the center console which makes me think I might have a bad transmission mount. My shifter does seem to be moving a good amount over bumps and I hear clack sounds sometimes too. I tried jacking it up a little to check, it did move but not a whole lot. What do you guys think?
Old Nov 6, 2013 | 06:51 PM
smurfet350zsrt4's Avatar
smurfet350zsrt4
my ***** even worst. I have a really hard racing clutch to drive and I'm pretty sure it's broke my trans mounts. the car, if not engaged specifically, will earthquake on me and will stop moving after a few feet until I push the clutch back in and restart the whole engaging again. even when I'm just cruising the shift **** moves up when I push in on the gas and moves down a little when I let off the gas pedal. the car is new to me so I can't really help you much but you are not alone haha good luck
Old Dec 14, 2013 | 12:03 AM
talmadgecook's Avatar
talmadgecook
Most probably it is a transmission problem there. so you must have to check it sincerey. I have been regular customer of Cook's Transmissions and it provides expert services that will makes your car running smooth as ever. It has done a good work on my auto repair needs. so, you must have to visit Cook's Transmissions once
350z82
Oct 1, 2015 06:25 PM
