Weak Starter/ Fuel Pump?
Old Sep 1, 2013 | 08:03 PM
350zadam's Avatar
350zadam
Default Weak Starter/ Fuel Pump?
I had the engine replaced in my 06 MT recently due to hydrolock, and everything is running smoothly, just as they were before. Only thing I have left to deal with is that now and then throughout the 10 or so starts each day i have, 3-4 are weak/shaky starts, and maybe 1-2 times it doesnt start at all, and i have to return/crank the key again.
Things that have come up, but are fixed:
Engine had to relearn idle, idled at about 1200-1300 when normal 7-800.
Squeaky pulley.
So my question is this: what do you guys think the issue with the ignition is? I haven't had the time to have it looked at yet, but I intend to soon.
More info:
Car Miles: 190k
New Engine Miles: 50k
Clutch was replaced with engine, so ~300 miles
Thank you for any info you guys can give.
Old Sep 1, 2013 | 08:16 PM
David_2613's Avatar
David_2613
Did the problems start before or after the clutch installation?
Old Sep 1, 2013 | 09:58 PM
350zadam's Avatar
350zadam
Clutch was replaced same time as engine.
Old Sep 1, 2013 | 10:04 PM
David_2613's Avatar
David_2613
Wow, how did I miss that?
Sorry, I don't have any suggestions for you. Search the forum, there are some good threads about starting issues.
Old Sep 2, 2013 | 04:02 AM
padilla03z's Avatar
padilla03z
does it make a noise when u start and it doesn't turn over? it could b the battery not giving enough juice, it could b the flywheel the installed sucks so it grinds, u need more detail or a vid of said incident but if u gonna get it checked out then it wont matter what we tell u, the mechanic is gonna trouble shoot it his way anyways
