Key SW fuse
Old Sep 24, 2013 | 04:53 PM
flynzed's Avatar
flynzed
Default Key SW fuse
I picked up a 350ZR about a year ago it is the touring model with manual tranny. I've noticed that if I let the car sit for more then three days the battery is weak. I desided to replace the battery but that did not correct the problem. I tested for battery drain when the car is off and found that it was pulling .22 amps. I started pulling fuses and when I pulled the key sw fuse it dropped to .15. Still not great but better. I down loaded the user manual however it does not provided any info on fuses. The key sw fuse is located in the fuse box in the drivers footwell. So what does that fuse provide power to?
lolwatbro
Oct 9, 2021 04:58 AM
Dr.Paulyy
Jul 29, 2019 07:45 AM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
Beater350z
Sep 9, 2015 03:36 PM
