clutch bleed.
Old Oct 18, 2013 | 12:09 PM
blackmamba89's Avatar
blackmamba89
Default clutch bleed.
Hey guys I just wanna know what's the easiest way to bleed my clutch on my 08 z. My fluid is really dirty and I just wanna flush an swap it out with fresh fluid, any suggestions thanks for your time.
Old Oct 21, 2013 | 05:30 PM
Itzcashew's Avatar
Itzcashew
Have a helped pump the clutch and hold it while you open and close the bleed valve.
In depth:
http://www.nicoclub.com/FSM/350Z/coupe/2007/cl.pdf
Go to page 7.
Old Oct 24, 2013 | 01:35 PM
zakmartin's Avatar
zakmartin
Honestly, the easiest way would be to take a syringe, suck the dirty fluid out of the clutch fluid reservoir, replace with new DOT-3 brake fluid and do this every few days for 2 weeks while you drive the car normally. It's a LOT easier than the other method for bleeding the clutch on a 2007 or 2008. By the time you're done, you've replaced about 75 - 80% of the old clutch fluid and it'll be fine. The best time to do a full bleed on the clutch is when you replace the master clutch cylinder, CSC and clutch line (with braided SS) while you're doing a clutch job and getting rid of all that OEM garbage. The aftermarket CSC is way easier to bleed (probably because it actually works).
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
