The oil pump has no pressure
Old Oct 15, 2013 | 06:22 PM
MJ_350z's Avatar
MJ_350z
Default The oil pump has no pressure
(I'm not good with English, sorry for grammar errors).My car is a Nissan 350z 08 ( VQ35HR ).We install a greddy twin turbo kit . We install Wiseco pistons, Carrillo rods, new bearing rods,we dont touch the main bearing because the car only has 30.000 miles, believe that should be new. We changed all o- rings and gaskets. Then assemble the engine,we dont touch the fuel system to verfy that everything was properly installed. We turned on the car and lit well,had a little problem in the revolution but nothing serious.The other day we changed the fuel system, walbro fuel pump , 750cc injectors , custom fuel rail,etc. We put a Microtech Efi Lt-16 to control fuel, time of engine with a crank trigger on the damper, let oem coils, but is connected to the Microtech, we left too the oem computer to control the rest.We turned on the car again with changes in fuel and Microtech, the car lit up with failure but we making some changes in the program of the Microtech and improved a little bit. The car Was on, like 25 min.while programming the Microtech, when suddenly the engine began to fail, wanted to turn off, oil light lit on the dash and then the oil pressure in the oil clock going to zero, we turn off the car quickly. We remove a oil line to the turbo to see if the oil pump had pressure, start the engine,dont had oil pressure. We think the oil pump was broken. Someone who can help me or know that could have happened ... ?
Old Oct 24, 2013 | 02:00 PM
DarkRain0660's Avatar
DarkRain0660
Could be a faulty oil pump or a small mistake while you were installing all the parts. Whenever I'm doing a build with more than a few parts I always replace the most obvious part that could be malfunctioning and then take everything back off and start over again to retrace my steps and see if I just made a mistake the first time. It normally works and turns out to be something really simple ( missed a plug, forgot to ground a wire, had something on wrong, didnt torque something right, forgot to double check something in my tuning software)
Old Oct 24, 2013 | 02:03 PM
DarkRain0660
Could also be the oem computer you are still using. My guess is that would also be the problem
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
