Dreaded P2A03 and P0430. Help?
Old Oct 31, 2013 | 03:21 PM
THolliday's Avatar
THolliday
Default Dreaded P2A03 and P0430. Help?
So I'll start by saying I had no problems with a check engine light or 02 sensors before I worked on my clutch. After I replaced my clutch I can't get rid of the P2A03 (Bank 2 Sensor 1. Circuit out of range). I also since replacing my clutch I have a pending code of P0430 (Catalytic efficiency bank 2). I hooked my car up to a scanner and ran live data and while idling one 02 sensor is reading .900 volts and the other is reading .460 volts. They move around a bit while I rev but not an insane amount. I have replaced both 02 sensors and the codes still come back. Any help would be greatly appreciated. I'm tired of throwing money and racking my brain on this one.
Old Oct 31, 2013 | 09:30 PM
sikkntbrah's Avatar
sikkntbrah
I also got the p0430 code a couple says ago.. Wondering if this is normal in z's? I'm going to the dealer tomorrow morning to see if it's something that can possibly replaced under the emissions warranty.
What year is your Z? Nissan provides an 8 year/80k mile warranty on emissions. If yours applies maybe try that?
Old Nov 1, 2013 | 05:22 AM
THolliday's Avatar
THolliday
I have an 07 it's still under warranty but I'm sure they'll find something that isn't under warranty to replace and make me pay
Old Nov 1, 2013 | 03:44 PM
sikkntbrah's Avatar
sikkntbrah
mine is actually at the dealer now and they confirmed it waas the cat and they are replacing it under warranty.
all they saaid is that they need to diagnose it. (which is $130) but if it is, in fact, a problem that is covered by warranty (emissions system) then i pay nothing at all. if its something not under warranty then all i pay is the 130 for the diagnosis.
i will let you know what else, if anything, comes up when i pickup my car later .
Old Nov 1, 2013 | 05:59 PM
sikkntbrah's Avatar
sikkntbrah
changed my cat for free. nothing else..
however, idk about your other code so yeah. haha
Old Nov 2, 2013 | 02:58 PM
THolliday's Avatar
THolliday
Well I may have a vacuum leak. I hear it around the pcv valve in the head. When I pull the vacuum line from the pcv the hissing stops. Any help with that? I feel like it may be tied into this problem
Old Nov 2, 2013 | 04:42 PM
Italianjoe1's Avatar
Italianjoe1
That would explain a little bit of the lean, but it shouldn't have anything to do with the clutch change.
I've seen the O2 sensor codes pop up from leaky header/cat joints, usually with aftermarket test pipes but if you removed the exhaust for the job it could be leaking there. It tends to suck in fresh air at idle and set lean codes.
TommyBoy76
Sep 16, 2004 02:17 PM
dikspiel
Feb 3, 2003 07:57 AM
