04 350Z not warmed up after driving hours
Old Nov 26, 2013 | 06:03 AM
RedBullRR's Avatar
RedBullRR
Default 04 350Z not warmed up after driving hours
Not sure what gives this just started... It's gotten real cold out here in NY. Drove my car for about an hour straight and the car never reached operating temp. In fact it stayed in the cold for a long period.
Turned car over this morning and again not warming up, and now I have a check engine light....
Any clues? I was thinking bad thermo, but it was replaced a year or so ago as well as the radiator..
Old Nov 26, 2013 | 08:40 AM
JCITY's Avatar
JCITY
Bad gauge?
When radiator was replaced--what coolant used?
Thermostat stuck open would be the first thing I'd check.
On the CEL--get a code.
Old Nov 26, 2013 | 09:33 AM
Syner's Avatar
Syner
Thermostat.
It doesn't matter if it was replaced a year ago, I've had some go bad in less than a week.
Old Nov 26, 2013 | 11:40 AM
jhc's Avatar
jhc
General & Tech Moderator
1) Coolant/overflow topped off?
2) After 15 min drive, open hood. Safely check for radiator and top hose heat. if no, suspect thermo stuck open or major air in system. if yes,
3) Suspect faulty coolant temp sender, which might trigger cel. get code.
Good Luck!
Old Nov 26, 2013 | 11:54 AM
RedBullRR's Avatar
RedBullRR
Went to Autozone on lunch, low antifreeze or bad thermo was the code it thru out. So yeah new thermo it is.
Chris350z03
Oct 8, 2023 07:19 PM
etkms
Jun 19, 2022 06:30 PM
350z_z33.
Jul 3, 2017 04:01 AM
Darkspy
Sep 7, 2015 09:09 PM
