Catalytic converter caught on fire
Old Dec 2, 2013 | 07:02 AM
420og35's Avatar
420og35
Default Catalytic converter caught on fire
Hey guys. So I bought a 350z 03 6 speed with a hydro locked motor. Bought a motor with 49k and I swpped the motors. After install had a few codes. Have cleared them all but p0328 knock sensor. But there is no knock so could that be a bad sensor???
So last night I added some seafoam into vaccuum and some into the gas tank since its been sitting for 6-8 months. After letting the seafoam soak we started the car and let it idle for a little while. The car sounded better and idled fine. Then Out of nowhere oil pressured dropped and my friend was outside the car and luckily he saw the flames and grabbed a fire extinguisher and we got it out.
No our question is why lol
Old Dec 2, 2013 | 02:21 PM
guitman32's Avatar
guitman32
You probably clogged the cats with the seafoam and all the crud it let loose. And if you did it in the vacuum and tank simultaneously doubly so. Ive done some research and the consensus seems to be to use the seafoam very gradually. And disconnect the cats if its a car.
Old Dec 2, 2013 | 06:11 PM
Spike100's Avatar
Spike100
I think the key here is your mention that the oil pressure dropped suddenly. You said:
Originally Posted by 420og35
[…] Then Out of nowhere oil pressured dropped and my friend was outside the car and luckily he saw the flames and grabbed a fire extinguisher and we got it out. […]
A sudden drop in oil pressure is very bad. It typically results in an excessive engine temperature. That temperature is quickly passed to a catalytic converter, and the result could be a fire.
--Spike
Old Dec 2, 2013 | 06:23 PM
jhc's Avatar
jhc
General & Tech Moderator
Seafoam 1,
Nissan 350Z 0.
Anybody else think it's the bomb? I've heard so many bad stories.
I hope you get your car repaired...
Old Dec 3, 2013 | 03:16 AM
420og35's Avatar
420og35
Well I'm doing everything myself. The car had coolant. I had just filled it up. I'm ordering some test pipes with bungholes for the o2 that will take care of the cats. But once I instal them I can keep diagnosing the car
Old Dec 3, 2013 | 05:40 AM
KornerCarver's Avatar
KornerCarver
In order to work, catalytic converters get very hot. Back in the 70's when catalytic converters were first installed on cars, there were several grass fires started under cars. I think heat shielding eventually solved that kind of problem.
sales@czp
Sep 23, 2019 03:30 PM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
Fixxxercask
Interior
Oct 6, 2015 10:17 AM
350z_z33.
Sep 9, 2015 09:50 PM
NYGiants0186
Sep 8, 2015 10:37 AM
