revup swap in im 03 de
Old Dec 3, 2013 | 04:23 PM
theZride03's Avatar
theZride03
Default revup swap in im 03 de
so i got a great deal on an 06 revup motor and trans abd my engine had went south.. anyways i did the full swap and im wondering if ill need a new ecu or if anyone has ran it off the De ecu. i have a revup harnes i just dint want to reprogram my new ecu due to nats and stuff. it runs with the de ecu but has realy high afrs and it seems to be running lean
Old Dec 4, 2013 | 12:00 AM
terrasmak's Avatar
You would need the ECU, best to convert the motor to a DE and run it that way.
Old Dec 9, 2013 | 04:51 PM
theZride03's Avatar
theZride03
what else would i need just an ecu?
Old Dec 9, 2013 | 04:53 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
I believe just an ECU
Old Dec 9, 2013 | 04:58 PM
theZride03's Avatar
theZride03
ok so i got my new ecu in today and i tryed to have my reprograming done at nissan and my 06 ecu wouldnt load
so here is my main question will i need the exact key fob dash harness to run this new ecu?
Old Dec 10, 2013 | 04:30 AM
NOLAGG's Avatar
NOLAGG
Good luck man , but why would you go with a rev up if they are known for all sorts of oil consumption problems rather then another DE?
Old Dec 10, 2013 | 01:11 PM
theZride03's Avatar
theZride03
i found the motor trans for 800 with harness just no ect
Old Dec 10, 2013 | 01:57 PM
theZride03's Avatar
theZride03
does anyone on here have a flashed 06 6speed with nats disabled for sale i will buy asap
Old Dec 10, 2013 | 04:18 PM
theZride03's Avatar
theZride03
help!!!! bumpp
Old Dec 19, 2013 | 09:32 PM
theZride03's Avatar
theZride03
so i got the natts turned of with uprev can some one help me with the wireing. its a 06 revup harness to 03 dash harness. i see a few builds saying to snip the white wire in battery compartment can anyone help me out
Old Aug 12, 2017 | 08:22 PM
mike99101's Avatar
mike99101
Did you figure this out?
SpartanZ32
Oct 22, 2015 09:36 AM
nissan1310
Oct 12, 2015 08:54 AM
SharX59
Sep 27, 2015 09:23 AM
