Front Driver Side Squeaking Noise!?!
Old Dec 13, 2013 | 11:08 AM
oiyitsc4ry's Avatar
oiyitsc4ry
Default Front Driver Side Squeaking Noise!?!
What is this weird noise coming from my driver side wheel well...I just rolled my front fenders the other day. I don't think that should be why though. The noise only occurs in the driver side wheel well and only occurs when I pop it into neutral or cruise. When I brake though, it stops. So I'm guessing it could be a worn bearing or something. Please, comments and input is encouraged. I don't know if this is normal or if this should be taken care of immediately. LMK asap please. Here's a video of it btw. Text me for a better response! Thanks. 3108186785 MY name is Cary.
Old Dec 17, 2013 | 04:40 PM
samsniss350z's Avatar
samsniss350z
It sounds like you've got a rubbing issue somewhere in the drivetrain. It doesn't sound like a bearing to me as that would present as more of a grinding/grumbling metallic noise, this almost (except for the rhythmic nature of it) sounds like the noise you'd get from shot drop links but as I say that's not as rhythmic as the noise your Z is making. I'd check all bushes and shafts just to see if anything is hanging up on something. Good luck with it.
Stevo Z
Oct 3, 2015 09:14 PM
Dymsi
Sep 29, 2015 11:32 AM
samansharif
Sep 25, 2015 12:31 PM
