Changing radiator/ removing fan help DIY??
Old Dec 27, 2013 | 11:44 AM
Stinvil93's Avatar
Stinvil93
Default Changing radiator/ removing fan help DIY??
My Z is overheating and my radiator is the culprit . Is their a DIY on how to remove the radiator/fan from the Z. I'm pretty good with working on my Z and past Z's this being my first 350Z. I just want to know what is the best method to pull out the radiator and swap it out. Just swapped the motor out don't plan on blowing this motor. Reply ASAP thanks! And yes I have searched.
Old Dec 27, 2013 | 11:50 AM
ProChargedZR's Avatar
ProChargedZR
Did you happen to use Google? Found this within 30 seconds...
http://www.zdriver.com/forums/350z-z...install-35786/
Old Dec 27, 2013 | 11:53 AM
pyshin's Avatar
pyshin
Nvm
Old Dec 27, 2013 | 12:42 PM
Stinvil93's Avatar
Stinvil93
I found a lot of stuff on the 370z and the moshimoto radiator. Thanks I'll give this a go tomorrow morning. I'll let you guys know how it goes
Old Dec 27, 2013 | 02:07 PM
WeightLimit's Avatar
WeightLimit
It's easy. I installed the Mishimoto rad/fan kit over the summer definitely worth the switch. Especially when you pull the factory radiator out and see the difference.
Old Dec 27, 2013 | 04:50 PM
Stinvil93's Avatar
Stinvil93
Yeah I am pulling out the rad tomorrow morning. Looks pretty simple for the most part pull the fan off the rad and everything else is pretty self explanatory. I got another stock oem rad from advance auto for now. But will switch it out in about a month and a half. I am looking at getting the Megan racing radiator. And I got another oem (Crappy plastic top and bottom) because I need my car running to get me to work Sunday Vs waiting 3-5 days for a new rad to come in.
Old Dec 30, 2013 | 02:06 PM
Stinvil93's Avatar
Stinvil93
Just to save everyone time and effort. Go to Nissan for Oem thermostat. I changed the thermostat prior to swapping my radiator out. Thinking it was bad only to find it was my radiator. The Duralast thermostat that autozone and pep boys has a completely set up. I was thinking that maby it was in improvement. NOPE. Stay Oem for the thermostat my cars runs like a beast again! And much cooler also.
lapham3
Oct 7, 2022 03:15 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
