Check Engine Codes
Old Jan 6, 2014 | 09:30 AM
JDM_35OZ's Avatar
JDM_35OZ
Default Check Engine Codes
So I was casually driving home on the highway and my Z decided to give me the service engine soon light.
Got it diagnosed and I had 3 faults.
P0327- I will be buying the knock sensor and sub harness to fix this.
P0139- the bank 1 o2 sesnor has a a low circuit, will also replace this.
The other code was P1147, and I can't find any info on that.
Just wanted to see if I'm going to be fixing it the correct way, any info/tips will be appreciated. Thanks!
Car is a 2003 manual with 90k miles.
Old Jan 6, 2014 | 12:36 PM
adrift_foolish1's Avatar
adrift_foolish1
bank 1 post cat o2 sensor
Old Jan 6, 2014 | 01:25 PM
myfirstzcar's Avatar
myfirstzcar
Don't forget the new intake gaskets with your knock sensor and sub-harness. I would do those first, then work on figuring out the O2 codes.
Old Jan 7, 2014 | 10:33 AM
JDM_35OZ's Avatar
JDM_35OZ
That's the one on the cat itself correct?
Old Jan 7, 2014 | 01:05 PM
myfirstzcar
After the cat.
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
