Climate Control Switch
Hey guys...
I looked a while on the forums before posting but I don't think anyone else has been having this trouble with their climate control switch
1) The middle button which is to allow air to flow in or to circulate the air within the car, is locked in the allow air in selection and no matter how many times I press it, it won't change...
2) The temperature selection at 60 is really 60 degrees, however if I roll it to around 65 degrees, it seems like it's around 78 degrees...
3) The left button which is the defog button will not turn the defogger on, the light won't turn on and the defogger won't turn on at all...
I've had this happen to me a while back but once I turned the car off and removed the key and then started the car again, it worked fine but last Friday when i selected for air to blow to the window it auto selected to flow air from outside, which i know is normal, but once i selected any other air exit, this problem happened and now it won't work normally.
I've tried unplugging the switches from the back and that also didn't "reset" the switch...
Any advice before I decide to buy a new climate control switch?? And if I do have to buy it, any advice from where? ConceptZperformance is selling for around $170...
Thanks!
Thanks!
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
CFAUVEL
Oct 1, 2015 03:20 PM
