Extreme power loss, rough idle. Help!
Old Dec 27, 2013 | 06:52 PM
EthanF's Avatar
EthanF
Default Extreme power loss, rough idle. Help!
I drive an 03 350z Touring, and a few days ago it did a small jerk while cruising on the highway, I figured it was because of the -2 degree weather. No other symptoms until yesterday driving to work it acted completely bogged down when taking off. Had trouble just revving it up to 3k to get going. Then it would straighten out for awhile, and then back to being sputtery. At times it almost seemed jumpy. At the stop light the idle would fluctuate, then rev up and normalize. The SES came on, but kept saying rear bank 2 02 sensor, as I have test pipes. Only mods are the test pipes, aem cai, and catback exhaust. I have no idea what's going on! Please help a brotha :/
Old Dec 27, 2013 | 06:59 PM
drvqz33's Avatar
drvqz33
Check your MAF sensor.
Old Dec 28, 2013 | 04:12 AM
myfirstzcar's Avatar
myfirstzcar
Try a little dry gas.
Old Dec 28, 2013 | 06:15 AM
JCITY's Avatar
JCITY
Did you get a tune after you added those mods?
Your car is prolly running lean,thats one thing.Also,
I'd check your cam position sensors.
Old Dec 28, 2013 | 10:30 AM
Spike100's Avatar
Spike100
Ethan,
You need to get the codes, but I’ll bet (I’m very certain) you need to replace your crankshaft and/or camshaft sensors. If your 2003 Z has more than 80K miles, it’s for sure that you need to replace some sensors. I recommend replacing both banks of both sensors. That saves $$’s later on avoiding a piecemeal repair.
You might throw a code for the O2 sensor, but wait on this until you replace the other sensors (which might fix the O2 code).
Your TPS and Throttle Body are probably OK. It’s possible to test the TPS with a multimeter. If the TPS tests as faulty, you should attempt adjusting it. If you cannot adjust the TPS, you need to replace the entire Throttle Body.
--Spike
Old Dec 28, 2013 | 05:27 PM
EthanF's Avatar
EthanF
As of now it's sitting at only a little over 43k miles, I changed the plugs, and cleaned the MAF sensor thoroughly. Took it for a short drive and it seemed good, the drive to work and back on Monday should tell for sure I appreciate all of you helping though! If this isn't solved the camshaft sensors are next on my list.
Old Dec 28, 2013 | 05:45 PM
myfirstzcar
So you didn't try a little dry gas? That would be my first guess on a -2° day.
You B2-S2 code is obviously due to the lack of catalytic converters, since the downstream sensors' primary function is to compare readings before and after the cats.
You'd be a fool not to add some dry gas and eliminate that possibility all together.
Old Dec 29, 2013 | 12:30 PM
Spike100's Avatar
Spike100
EthanF is no fool (as you suggest) for not trying “dry gas.”
Originally Posted by myfirstzcar
So you didn't try a little dry gas? That would be my first guess on a -2° day. You B2-S2 code is obviously due to the lack of catalytic converters, since the downstream sensors' primary function is to compare readings before and after the cats.
Actually, Ethan has already solved the problem, and the fix never required your “dry gas.” advice.
Old Dec 29, 2013 | 01:28 PM
myfirstzcar
Yeah well dry gas has solved issues like this before. Always start with the obvious things first.
What was the fix? Haven't heard for sure yet have we?
Old Dec 29, 2013 | 02:13 PM
Spike100's Avatar
Spike100
Apparently the fix was not "dry gas."
Old Dec 29, 2013 | 04:48 PM
myfirstzcar
We still don't know the problem is fixed though do we, as post #6 would indicate.
Old Dec 30, 2013 | 06:07 PM
EthanF's Avatar
EthanF
You guys....plz dnt fight! Anyways, I've driven about 130 miles since the last post and it seem to be running good!!! Still have the stupid SES light form that darn 02 sensor though haha, even after 2 resets. I wonder if dry gas might not be a bad idea anyways just in case there is a little condensation?
Old Dec 30, 2013 | 06:39 PM
Spike100's Avatar
Spike100
^^ We are not fighting... we are debating, and we are presenting different ideas/solutions/answers. It's all in fun and what makes these forums interesting.
It would be boring if everyone was super-polite and there was no controversy whatsoever.
--Spike
Old Dec 31, 2013 | 05:01 AM
myfirstzcar
Spike, that is the smartest thing you've said since I came back here, I have to agree with you
Again with the dry gas, what have you got to lose? A bottle of iso-heet is like 2 bucks. If it were me, I would have to know that possibility is ruled out. I've had cars freeze up before and it's not fun. They usually do it when they get below half a tank in super cold weather.
Old Dec 31, 2013 | 05:15 AM
travlee's Avatar
travlee
Master
it never hurts, especially being in minneSNOWta... gets damn cold there... so glad me and the ex didnt work out because i would have to move there....i like my mild texas winters
Old Dec 31, 2013 | 05:26 AM
350slug's Avatar
350slug
I had a funny idle in my g and I cleaned the throttle body and it was good. I just put a spacer in my z and cleaned the tb just cause. The z was way dirtier with way less miles and wasn't giving any idle probs. anyways it's clean now. Tb gasket is 5$, sometimes it's cheap fixes that we overlook. Clean engine= happy engine
Old Jan 1, 2014 | 09:03 PM
EthanF's Avatar
EthanF
Well poop on my chest, the problem has returned! Again for a split second while accelerating in 3rd it seemed to have trouble until it got above 3k rpms. And yet again, the weather was about -3 below zero. Next step is dry gas, and cleaning the throttle body! I'm going to attempt doing that without removing it as I'm worried about damaging something hahah. I really hope this thread ends in me with a fixed car, and a solution for someone to fix theirs in the future :P
Old Jan 1, 2014 | 09:15 PM
EthanF's Avatar
EthanF
On a side note: this is the first winter this car has ever been driven in the 11 years of it's existence, and I do have 17 inch winter wheels in place of the stock 18's. I don't suppose this could be messing with the VDC?
Old Jan 2, 2014 | 12:00 PM
myfirstzcar
If you have vdc, the wheel and tire size doesn't really matter. What does matter is the diameter difference. They can be the same size, or "square", but they can't be more than about 3/4" different from front to back.
I'm sure someone has the exact difference in circumference all figured out somewhere.
EDIT, make sure your throttle body hasn't had a coolant bypass done to it.
Old Jan 2, 2014 | 03:29 PM
Spike100's Avatar
Spike100
Ethan... What are your tire sizes? --Spike
