help!!!!!!!!!! oil covered spark plugs
Old Feb 22, 2014 | 11:35 PM
nj_eveohviii's Avatar
nj_eveohviii
Default help!!!!!!!!!! oil covered spark plugs
im curious if anyone had a suggestion what this could be i pulled my 2 plugs by fire wall i think its 5 and 6 and they were covered in oil alot others were fine just those 2 my car is throwing p0300 code p0301 bogging out valve cover gasket? but that seems too easy lol if anyone had this problem lmk thanx
Old Feb 23, 2014 | 02:13 AM
sracura's Avatar
sracura
Op, research oil in spark plugs. it will have your answer.
Old Feb 23, 2014 | 02:51 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Prepare 4 a new engine
Old Feb 23, 2014 | 03:59 AM
terrasmak's Avatar
The oil was on what side of the plug?
Old Feb 24, 2014 | 02:47 AM
nj_eveohviii
i pulled plug the entire plug and my socket had oil on it
Old Feb 24, 2014 | 03:13 AM
sradenton's Avatar
sradenton
To me sounds like spark plug tube seals. Post pics
Old Feb 24, 2014 | 07:27 AM
seymore4's Avatar
seymore4
Professional
OP this is a very common problem, you need to replace the valve cover
Old Feb 24, 2014 | 07:40 AM
travlee's Avatar
travlee
Master
spark plug tube seals???? wtf SMH
Old Feb 24, 2014 | 07:42 AM
seymore4's Avatar
seymore4
Professional
???? You've never heard of the spark plug tube seals failing on a DE and having to replace the valve cover? Pretty common problem...
Old Feb 24, 2014 | 07:46 AM
travlee's Avatar
travlee
Master
that is the valve cover gasket....
Old Feb 24, 2014 | 07:48 AM
seymore4's Avatar
seymore4
Professional
Old Feb 24, 2014 | 08:03 AM
travlee's Avatar
travlee
Master
Originally Posted by seymore4
ooooooooh, i see the rings that you are talking about..... never knew about those. but do they really go bad or more the gasket?
Old Feb 24, 2014 | 08:12 AM
seymore4's Avatar
seymore4
Professional
The spark plug tube seals are built into the valve cover, you have to replace the whole thing. When they go bad they start leaking oil into the spark plug tube, pooling and eventually covering the plug and bottom of the coilpack. I've seen some so bad that when the coilpack was removed you could barely see the top of the spark plug.
Old Feb 24, 2014 | 08:23 AM
taywan's Avatar
taywan
Ya time for some new valve covers
Old Feb 24, 2014 | 08:48 AM
sradenton's Avatar
sradenton
If it is the spark plug seal Just replace the valve covers or have R@D factory fix them or buy the kit and do the diy.
Old Feb 24, 2014 | 09:01 AM
travlee's Avatar
travlee
Master
i stood corrected and acknowledged it....
Old Feb 24, 2014 | 09:44 AM
goose691's Avatar
goose691
I have the same issue, it's not a big deal, just you valve cover gaskets that go around the spark plug bays, not to big a job, ill be doing mine sometime this week, I have a nice pool of oil in the #6 plug bay
Old Feb 24, 2014 | 11:09 AM
HK350 Z's Avatar
HK350 Z
I just had the same thing during a tune up , yes you have to buy both valve covers to replace the spark plug tube seals, each cover was about $215.Mine was just a little oil...
Old Feb 24, 2014 | 05:06 PM
2004Black350z
Exhaust Whore
Rebuild
Old Feb 24, 2014 | 05:15 PM
saywat?'s Avatar
saywat?
hit up this guy "G35TSS" on g35driver maybe hes on here too idk. they sell same stuff as R&D except better service and communication
