seatbelt buckle won't release
Old Apr 4, 2014 | 07:13 AM
mcubed45's Avatar
mcubed45
Default seatbelt buckle won't release
Exactly like the title says. The buckle just won't release. Any ideas? The seatbelt was working fine prior to this. Luckily my passenger was able to get enough slack and wiggle out from under the belts.
Old Apr 4, 2014 | 11:07 AM
Spike100's Avatar
Spike100
You should be able to get a replacement at no charge.
Old Apr 4, 2014 | 12:23 PM
Whiteazn2's Avatar
Whiteazn2
I don't know why it's doing that. I know when your airbags deploy they lock up but obviously you didn't get in a accident so idk why its locked up. But try to do what spike said.
Old Apr 4, 2014 | 03:08 PM
mcubed45's Avatar
mcubed45
thanks for the replies!
Went out in the morning to mess with it some more and it finally released. Just shook it around a bit. Seems to working fine now... not sure what happened
Old Apr 4, 2014 | 03:36 PM
kenpla2's Avatar
kenpla2
Look to see down in if anything fell into the release mechanism & causing it to jam. Because of a lack of space to be free internally, it might jam again, if this is the case. Just a thought !!!!
Old Apr 25, 2014 | 04:31 AM
mcubed45's Avatar
mcubed45
well **** it happened again today. While I was the passenger. And I had no slack on the belt so I couldn't wiggle out. Luckily I had my ratchet set. Unluckily it was in the glove box behind the passenger seat. That was not fun. Eventually we managed to just unbolt the bottom mounting bolt. Messed with the latch some more and it eventually released and started working normally again... >.<
Will the dealer really replace the belt/buckle at no charge? If not I was gonna start trying to source a used one.
Old Apr 25, 2014 | 08:54 AM
Spike100's Avatar
Spike100
The factory seat belt system is warranted forever.
Old Aug 1, 2014 | 12:16 PM
mcubed45's Avatar
mcubed45
So it's been doing this a lot more. Finally called Nissan and seatbelts are only covered by a 10 year warranty.. which expired last year. My local dealership had me try calling corporate to see if they'd cover it since I'm only a couple months out but corporate said they needed an official diagnostic done before they could process my request. The part's only $45 so I said no thanks. Oh well.
So FYI for anyone having belt problems, it's only 10 years. I think it's specified in the manual too.
Old Aug 1, 2014 | 03:13 PM
Spike100's Avatar
Spike100
They told you garbage. You can save the $45 if you are willing to fight for it.
A seat belt repair is a free fix… FOREVER. There is no such thing as a 10 year limit.
I recently had my 20 year-old Montero’s seat mechanism replaced. There was no charge for this service. The belt retraction system was failing.
Old Aug 3, 2014 | 10:38 AM
mcubed45's Avatar
mcubed45
it's actually in the manual
Old Aug 4, 2014 | 12:10 PM
mcubed45's Avatar
mcubed45
Old Aug 4, 2014 | 12:39 PM
Spike100's Avatar
Spike100
I'm wrong. The Nissan lifetime warranty for seatbelts does only apply to Nissan cars older than 2003 (2002 and older).
Here is the information:
http://www.nicoclub.com/archives/are...-for-free.html
(I hope the link works on this forum).
Some manufacturers do provide a lifetime warranty on seatbelts
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
