TCS slip blips on acceleration - not wheel slip
Old Apr 5, 2014 | 02:35 PM
CroneOne's Avatar
CroneOne
Default TCS slip blips on acceleration - not wheel slip
Hi all,
Before taking my Z into the shop I thought I'd ask here. I recently had my differential worked on and had 4.08 gears and a Quaife lsd put in. Previous to this I had no problems with TCS. Now, when in 3rd gear or 4th gear when I put down fairly hard acceleration, the TCS cuts in even though there is no wheel spin. I had to disable it for a whole track day for the 1st time. It seems that the sensor is out of whack and was wondering if new gears/lsd would confuse it?
I run 265/40/18 r and 245/40/18 f but they were perfectly fine before the diff work.
Is there a way to calibrate the TCS? Would the ABS diff sensors be a culprit?
Cheers!
