Antifreeze leak found but where is it from
Old May 4, 2014 | 09:09 PM
will_z32's Avatar
will_z32
Default Antifreeze leak found but where is it from
Okay so i drive a 2003 track. been chasong a small antifreeze leak for a while now. As of today i found a little bit of antifreeze while changing the oil. I saw it right above the oil pan on the block. It is on the opposite side that the oil filter is on. Belo0w is a pic, wondered if anyone knew where this might be coming from. Also the very bottom of the pic is the oil pan. Thanks much in advance.
Old May 4, 2014 | 09:26 PM
SR71's Avatar
SR71
Lead Super Moderator
http://wiki.answers.com/Q/Do_you_use...leaks?#slide=1
Twenty4
Jan 17, 2016 01:20 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
