Fuse or pinched wire?
Recently I was replacing my rear trunk light. When I inserted a new led bulb, I noticed a small spark/some smoke appeared. I'm curious if a fuse was blown, or there's some pinched wire that caused this (or both). All my other interior lighting works fine. One thing I have noticed though is my rear defroster button isn't working anymore... I'm not sure if replacing the trunk bulb caused this, but it was working fine before this occurred.
Any input will be greatly appreciated for both issues. Thanks in advance.
LED lights need to be installed with the correct polarity (positive side vs. ground side) as opposed to a standard bulb that can be installed either way. If you got a spark and are getting no light, you're reverse-biased and may have shorted something during the installation process or killed the LED altogether.
If you haven't done so already, return everything back to the way it was originally. If it's working, then the problem is probably with the LED (meaning, you installed it the wrong way.)
350Z_Al
Oct 29, 2020 07:44 PM
350Z Project X
Oct 17, 2015 05:16 PM
Beater350z
Sep 9, 2015 03:36 PM
