MAF help
Old Jun 18, 2014 | 05:19 PM
john3636's Avatar
john3636
Default MAF help
Hey guys, I'm new here and would like some input to a problem. My car started bogging down and dying the other night (VQ35HR). So I plugged in my scanner and noticed that my IAT was about 20 degrees off. So I took out the MAF, cleaned it with some cleaner, and it idled fine. Still couldn't drive past 2.5k RPMS. So I plugged the scanner back in after the car started dying again and now its reading 30 degrees higher than it should be. My MAF had a reading of .2lbs/min. I'm assuming that's to low because on another forum I found stated it should be around 3-4lbs/min. My question is, is the MAF reading what it should be, or should it be that 3-4lbs/min. Thanks for the help
Old Jun 20, 2014 | 02:03 PM
zakmartin's Avatar
zakmartin
Check the FSM.
Old Dec 15, 2014 | 09:32 AM
Dekker001's Avatar
Dekker001
nvm
Old Dec 20, 2014 | 04:25 PM
0jiggy0's Avatar
0jiggy0
What makes you say the iat is reading incorrectly?
etkms
Jun 19, 2022 06:30 PM
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
