Halp with door/seatbelt/headlight chime
Old Aug 12, 2014 | 12:16 PM
thane_marshall's Avatar
thane_marshall
Default Halp with door/seatbelt/headlight chime
So I finally got to make my daily commute in my Z after she had about a week of downtime due to the oem thermostat failing at ~90k miles. I replaced the T stat but I plan to do a coolant flush today or tomorrow as I just threw a 50/50 mix of O'Reilly coolant and distilled water in it to get it home when I later realized it was "low-silicate" coolant.... Anywho, before I could resolve that issue, or the many other bits that need attention that are slowly surfacing one by one (but thats a whole other story and I'm beginning to ramble on...) I was getting in the car to grab lunch today when I noticed that my seatbelt chime only rang twice and was then followed by a "half-chime" ... I ignored it until I got to work and opened my door to notice that I wasn't hearing any chimes for having my keys in the ignition. I was kinda joyful at first, since it's not exactly a catchy pop song, but I know it's there for a good reason. I can only imagine it'll be a matter of time before I lock my keys in the car or leave my headlights on.. I searched around online with no result and I'm still at work so I haven't really broken into the manual yet. Has anyone had this happen before? I'm hoping its just a fuse or something.. I still have my check engine light from the car over heating ... go figure ..
Halp. I need my annoying chimes back guise
Old Aug 12, 2014 | 05:27 PM
teamevolution2's Avatar
teamevolution2
Fixed mine by replacing the blown fuse in the fuse panel on driver side kick panel. If I remember its a 15 amp fuse. Hope this helps.
Old Aug 13, 2014 | 12:00 PM
Blaineanator's Avatar
Blaineanator
Either change the fuse or reset the ECU.
Old Aug 13, 2014 | 04:25 PM
thane_marshall
Thanks for the suggestions guys! I was checking the fuses last night and none were shot.. I got frustrated when my fuse pullers stripped and wouldn't pull any other fuses so I kinda just left it for the night. Then today, again at lunch, it randomly started chiming again! I guess it just needed a nap? Hopefully it won't cut out again *knocks on wood*
z33z_nutz
Sep 23, 2015 07:22 PM
lsdunique
Jul 21, 2009 09:40 AM
350fanatic
Northern California
28
Jan 27, 2005 02:13 PM
slay2k
Apr 13, 2004 06:15 PM
trust
Mar 17, 2004 01:55 AM
