Worst 350z Clutch Pedal Squeak/Creak
Old Sep 9, 2014 | 08:14 AM
MagPulMyMag's Avatar
MagPulMyMag
Default Worst 350z Clutch Pedal Squeak/Creak
Hey, guys well after some searching here on the forums its seems this a common problem that plagues our cars, however id like to post my video of my clutch pedal its pretty horrendous.
Here is the description from the video i posted "This is believed to be coming from a rubber grommet within the firewall for the clutch linkage, the pedal itself has been thoroughly lubed with bearing grease at the pivot points so its not the problem. Happens a lot on hot summer days not so much when the weather is temperate."
I really need to solve this.
Old Sep 9, 2014 | 04:01 PM
RacingBlack350Z's Avatar
RacingBlack350Z
I have the same problem, not a big deal but a really annoying and embarrassing almost when I have someone in the car. I may just take the pedal apart some time and replace all the rubber pieces.
Old Sep 9, 2014 | 04:30 PM
craig12895's Avatar
craig12895
I also have this issue. What piece is it exactly that causes the squeak? Because mine has gotten significantly worse over the past few months. Can it actually be replaced without buying a whole new clutch pedal assembly?
Old Sep 9, 2014 | 04:35 PM
RacingBlack350Z
I'm not too sure, I was thinking about just taking the pieces to O'Reilly's hoping they would have replacements. If you get upside down in the seat you can see the joints way up at the top. I've used silicone lubricant multiple times, but within a month it comes back. I highly doubt you have to buy a new clutch assembly, that would be over the top for something so small.
Old Sep 9, 2014 | 04:36 PM
travlee's Avatar
travlee
Master
i would get some spray lithium grease and hit everywhere that moves
Old Sep 9, 2014 | 05:10 PM
craig12895's Avatar
craig12895
Ive gotten under the dash and pushed the pedal in and i can't find an exact spot that it is coming from. And yes a new clutch assembly seems over the top, but I wouldn't put that past nissan
Old Sep 9, 2014 | 05:32 PM
RacingBlack350Z
Yea I use the stealership for diagnosis of problems, never for work or parts. I never take their advice without backup from this site.
Old Sep 9, 2014 | 07:21 PM
NismoDude's Avatar
NismoDude
Get one of these.
Fix whatever is creaking AND greatly improve the feel of your clutch.
https://my350z.com/forum/engine/5911...50z-g35-s.html
Old Sep 9, 2014 | 08:12 PM
Jennifer 2's Avatar
Jennifer 2
MagPul, this squeak is coming from the Clutch fork as it pivots over the ball stud.
You need to get under the car, pull back the rubber boot in the bell housing and using a strong light and some contortionist moves locate the pivot ball under the clutch fork lever and lubricate it. The guy who did mine used a stiff acid brush to reach in and force some anti seize lubricant between the clutch fork lever and the ball. I guess in a pinch you could use some wheel bearing grease. Don’t just randomly spray oil into the bell housing, as it will make a mess on the clutch assembly.
The clutch fork lever works against the very heavy clutch pressure plate spring so don’t wait too long before remedying this, as without lubricant the pivot ball will take a beating.
Old Sep 9, 2014 | 08:40 PM
NismoDude's Avatar
NismoDude
Old Sep 10, 2014 | 03:11 AM
craig12895's Avatar
craig12895
So you're saying there is no noise coming from the actual clutch pedal assembly but rather its coming from the trans?
Old Sep 10, 2014 | 03:12 AM
travlee's Avatar
travlee
Master
the way i heard it, it was inside the car....
Old Sep 10, 2014 | 08:00 AM
Jennifer 2's Avatar
Jennifer 2
Craig, you can confirm this diagnosis by getting someone to push the clutch pedal down and then let it up slowly. Crouch down just behind the left front wheel and listen for a squeak coming from underneath the car. You can just see the area where the slave cylinder pushes on the end of the clutch fork. The squeak will be coming from the pivot ball hidden behind the rubber cover on the bell housing.
This is a common maintenance item on many makes and models of cars using this type of clutch linkage. We lubed mine after 10 years service when it had just the faintest squeak. (preventive maintenance)
Old Sep 10, 2014 | 09:02 AM
craig12895's Avatar
craig12895
Im with Trav, I thought it was inside but you are obviously talking from experience.
Within the next month, Im getting a new trans and clutch. Will that fix it? Otherwise I should obviously lube mine while its going through that maintenance
Old Sep 10, 2014 | 09:06 AM
travlee's Avatar
travlee
Master
get a new pivot ball.... they are cheap and they do wear down
Old Sep 10, 2014 | 09:11 AM
craig12895's Avatar
craig12895
Ok so you confirmed for me that it is the pivot ball and not the rubber pieces. Well the JWT clutch kit comes with a new pivot ball so my problem should be solved.
Thanks for the advice. OP sorry I kinda jacked the thread but hopefully all the info helped you too
Old Sep 10, 2014 | 09:13 AM
travlee's Avatar
travlee
Master
put anti-seize on it before placing the clutch fork back on it
Old Sep 10, 2014 | 05:39 PM
MagPulMyMag
Well to clarify some things after this video was posted i had a friend press and depress the pedal and i put my head "in" the engine bay it defiantly isn't coming from inside the car. It is probably coming from underneath like the previous poster said.
Also guys thanks for the flood of posts on here, one day i look and it is barren, the next there is like 20.
Old Sep 10, 2014 | 05:44 PM
MagPulMyMag
Originally Posted by NismoDude
Get one of these.
$250 Ouch! Though after looking at this system the build quality does seem to be immaculate, Damn it now your making me want to go and spend more money!
Old Sep 10, 2014 | 05:47 PM
travlee's Avatar
travlee
Master
spray lithium grease on all parts that move on the pedal under the dash....
