P1147
Old Jan 29, 2015 | 07:51 AM
Whiskers1996's Avatar
Whiskers1996
Question P1147
I got this code on the highway going aprox 80 mph and reset it. I just got the code again about 4 days later on the highway doing the same speed.
I checked the sensors and the harness and they seem fine. I know I do not have any leaks in the intake/exhaust. Should I have the fuel pressure and fuel injectors checked or just replace the sensors? I have an aftermarket intake/TP's/catback and I am tuned. I have had no problems since being tuned.
Can't seem to find much for this code.
Anyone have some exp with code?
Old Nov 21, 2023 | 01:18 AM
darkwhitenes's Avatar
darkwhitenes
Default Did you ever find a solution? The same exact thing just happened to me.
i was driving at around 80-90 on the freeway when I got a CEL, checked it when I got home and I saw in my pending codes the same one. I do have a bad 02 sensor because I get codes for it here and there. Did you ever find a solution?
Old Nov 22, 2023 | 03:21 PM
Whiskers1996
I had 2 problems causing my issue..
#1. Was missing the gasket for the MAF sensor.
#2. Secondary o2 sensors. They worked fine; however, they made the ECU think it was running lean. It would throw lean codes ut run VERY RICH. I would be sitting at high 12s low 13s just at idle. Unplugging the rear 02 sensors fixed the issue. You will have a CEL still, but it will be fixed. I do want to clarify and say this seems to be mainly an issue for 2004.5's with testpipes/high flows.
solidfish
Jul 22, 2011 10:42 AM
ms350z
Nov 15, 2009 04:38 PM
Sly_Z
Mid-Atlantic
Sep 8, 2008 02:27 PM
xsmallpaulx
Oct 13, 2007 01:51 PM
booger
Jul 6, 2005 11:44 AM
