Trip computer not working
Old Apr 20, 2015 | 01:46 PM
pr_350z's Avatar
pr_350z
Default Trip computer not working
Hello my trip computer will turn on but stay on the:" --- mph " screen. Tried using the controls on the main cluster, but the trip computer wont respond. I already unplugged it and plugged it again, that did not work, and I replaced the trip computer(the 3 on the center) with another I had, and that wont work either.
Any ideas on how to solve this?
Old Apr 21, 2015 | 12:48 AM
amr_electron's Avatar
amr_electron
Start with an OBD scanner, U1000 code can cause this, Also check the connection between the triple meter and the unified meter/AC amp .
Old Apr 25, 2015 | 01:23 PM
pr_350z's Avatar
pr_350z
hello, could not check anything with OBD scanner since the CEL light wasnt on. But I did check the unified meter/AC amp, and on the connectors on the back of it, one was completely broken, soldered a cable, re-attached everything. Everything is working now, except that I cannot see the option to set the shift light. Could the missing shift light settings may be absent if the unified meter/ AC amp was replaced by the previous owner using an automatic transmission meter/ AC amp?
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
