vibration at 80 mph, comes and goes
Old 11-13-2015, 05:12 PM
  #141
travlee
Master
travlee's Avatar
Received 9,056 Likes on 6,521 Posts
you have a buddy with a Z? swap driveshafts, see if problem persists... will just cost ya some time and beer
Old 11-13-2015, 05:23 PM
  #142
black38
black38's Avatar
new city, no friends
plenty of beer though
Old 11-13-2015, 05:26 PM
  #143
travlee
Master
travlee's Avatar
post up in regional section, i bet someone would help ya.... and you get to meet new people at same time
Old 11-14-2015, 09:00 AM
  #144
black38
black38's Avatar
i have, something about nashville that is exclusive.
I'm not a big meet kinda guy but i'll probably look for a facebook group.
Hard to let someone swap a driveshaft without knowing them for awhile
Old 11-15-2015, 06:44 PM
  #145
black38
black38's Avatar
i am really at a loss, I do not want to drop the trans to look at the clutch or the pumpkin...this sucks. Why can none of these shops help...
Old 11-16-2015, 04:01 AM
  #146
timeltel
timeltel's Avatar
Near Nashville? Doug Crawford at Crawfords Z Car Garage:
http://www.yelp.com/biz/crawford-z-c...ce-nashville-2
One of the best.
Old 11-16-2015, 04:27 AM
  #147
Vigman
Vigman's Avatar
Is the wobble EXACTLY the same as it has ever been??
You NEED to have the driveshaft MEASURED...... ( by someone who KNOWS how to use that tool )...
Can you recap everything that has been done or experimented with ?
Old 11-16-2015, 05:28 PM
  #148
black38
black38's Avatar
One of the best.
Right close to nashville. 15 mins or so away
I'd be curious to know why you think he is the best?
He was the second shop that had it and suggested I go get a $200 tire balance.
Recap of everything done
- Stock set of wheels and tires tried
- Tires mounted and balanced x4 (wheels tested and were true)
- drive shaft unbolted to check u joints
- Diff bushing replaced
- rear shocks replaced
- Driver side axle replaced
- Car was put on a dyno and while on the dyno it shook like it was on the road. (hence all the rear end work)
I reading other threads with similar shakes and people are saying replacing the compression rod bushing fixed it. It just doesn't make sense on my car as the bushings look good and the dyno run makes me think its in the rear.
I'd like to add that every shop except the very first has had the car for at least 24 hours to diagnose a problem.
Old 11-16-2015, 06:53 PM
  #149
guitman32
guitman32's Avatar
Burn it already. This is getting ridiculous.
Old 11-17-2015, 04:10 AM
  #150
Vigman
Vigman's Avatar
Just checking the U joints visually, is not enough... it must be measured. Failing that, it's just guess work, and FRUSTRATION. Take it to Nissan and let them have a look at it...
Things turning at a high rotational speed only need to be a gram or a thou or 2 to do this.
Has the car ALWAYS done this, since you owned it?
Old 11-17-2015, 05:39 AM
  #151
timeltel
timeltel's Avatar
"I'd be curious to know why you think he is the best?"
Please don't misquote. Wrote "One of the best".
Doug Crawford has specialized in Z's for 35 years.
Might do you good to talk to him & let him know what's been done. He's very accessible.
Other options might be to pick up a $100 driveshaft & a four bolt DIY or make an appointment for diagnostics with Dynosty in Louisville.
Sympathize with your problem & appreciate your goal of keeping your Z in good mechanical form. Good luck!
Old 11-17-2015, 04:04 PM
  #152
black38
black38's Avatar
I think this answer the best.
I live at 123 main st and will roast marshmallows with you while it burns
Has not always done this or i would've burnt it by now.
4 months and counting.
While i don't doubt he's worked on them for that long. He could not fix my problem. He was the second shop I took it to.
He also had a problem taking it up to 80 mph (he wouldn't do it)
He told me what I would've expected nissan to tell me...live with it.
I guess i will leave it with a shop over thanksgiving and have them pull the driveshaft and get it checked. maybe i'll just part it out and call it a day...semi serious
Old 11-18-2015, 06:16 AM
  #153
JCat
JCat's Avatar
If you ever need a doctor for a health problem, please let someone else choose one for you.
Old 11-18-2015, 07:44 PM
  #154
black38
black38's Avatar
anyone else have any ideas?
Old 02-04-2016, 10:30 AM
  #155
Thats13guy
Thats13guy's Avatar
Has this been rectified? I have the same issue with my 07 z. I have full camber/toe battle version arms in the rear with new energy diff bushings. Just had an alignment and wheel balancing done. I have the "bouncing up and down" feeling after 20-35ish and the vibrations through the driveline/shifted/seat around 70-85ish. It vibrates even when clutch is pushed in(vibrations increase while under load obviously). Any help is great, thanks!
Old 10-21-2018, 10:16 PM
  #156
Rocky91890
Rocky91890's Avatar
I'm in the same boat now too, and have been referring back to this thread in hopes to find a solution to my issue...replaced 2 sets of tires, axles, had run out tests done on rotors, hubs, drive shaft. Replaced differential bushings, trans bushing, and still nothing has been fixed. If anyone here, yes I know how old this post is, has any other advice, I would greatly appreciate it.
TrboMike
North East
09-28-2015 06:36 PM
CrowzRSA
09-21-2015 04:00 PM
FromGtoZ
09-20-2015 03:41 PM
T'S 350Z
Event Photos
13
09-17-2015 12:55 AM
fst100
North East
09-08-2015 11:37 AM
Quick Reply: vibration at 80 mph, comes and goes
