Driver Window not working.... no solution
Old Jul 22, 2015 | 02:25 PM
Teh_White_Z's Avatar
Teh_White_Z
Default Driver Window not working.... no solution
Ok so I've had my 2007 Touring 350z for about 4 months now and the driver window hasn't worked since I drove it off the lot. Having changed a few window motors in my life I figured it was a quick swap and i was good to go. So after trying the method of taking it apart and cleaning it real good, so i didn't have to drop the $100+ on a new window motor there was no luck. It doesn't do anything at all... not up, not down, nothing. So i broke down after not having any other guess's and done lots of research, I bought a new driver window motor. Got it in the mail yesterday, everything looks good. Go to install it today..... and nothing. so I have now completely ripped this annoying door apart by myself probably 3-4 times, dropped $120 in stuff trying to find a solution and I've got absolutely no where.... The only other thing I can think of is the switch module that sits in the door could have a short in it or something. Thus being because when I first close the door and turn the car on I can Lock/Unlock, mess with mirrors, roll passenger window up and down. But as soon as I touch that switch for the driver window nothing else works after until I restart the car. What do you guys think? Am i on to something with replacing the switch? Or am i wasting my time messing with it, because I'm completely out of ideas here...
Old Jul 22, 2015 | 03:10 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Have you tried testing the old window motor? That might tell you something. You could also check the new motor and see if you have a dud. It's also not hard to pull the switch panel and check the DS window switch with a multimeter to determine if it's functioning.
Bottom line: don't just throw parts at the car...
Old Jul 22, 2015 | 04:47 PM
travlee's Avatar
travlee
Master
if you have a friend with a Z, borrow their panel and see if things work with theirs
lapham3
Oct 7, 2022 03:15 PM
Uriyo_
Sep 8, 2021 08:46 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
