Revving issues.
Old Nov 14, 2015 | 02:31 PM
Ghalleo's Avatar
Ghalleo
Default Revving issues.
Ok so here's the problem. My car starts fine and idles fine however, when I rev the engine, it revs fine but when the needle is coming down it goes below 800 to 400 or 500 and comes very close to stalling. It manages to catch itself then resume running normally. I'm not sure if it may be a vacuum leak because there aren't any visible signs that there's a leak. A many inputs as possible will be greatly appreciated. Thanks.
Old Nov 14, 2015 | 04:39 PM
rancor's Avatar
rancor
Sounds like you might just need to do an idle air relearn. Just check the air filter first. You can also clean the mass airflow sensor and throttle bodies but read here before you do that as people have caused damage to there Zs cleaning them wrong.
doc_sus
May 20, 2016 05:04 PM
ajcool2
Apr 6, 2016 07:11 PM
savedbygrace
Nov 24, 2015 06:26 AM
dani3ln3al
Nov 18, 2015 05:15 PM
max.e.urena
Nov 13, 2015 06:10 AM
