car vibrates after installing coilovers need help!!
Old Nov 12, 2015 | 07:14 PM
max.e.urena's Avatar
max.e.urena
Default car vibrates after installing coilovers need help!!
hey guys i am really hoping someone can help me shed some light on whats going on with my car. a recently installed bc racing coilovers, ichiba spacers and spc rear camber kit. then i had my car aligned at a shop. when i was driving home i noticed that when i get to 80 mph on the highway. my steering wheel starts shaking and the problem gets worse on bad stretches of road... it doesn't happen when i keep it under 80 though. i did some research and i read it could be the spacers or the sway endlinks. i did take a look at the endlinks and they dont sit parallel like the used to. i did lower my vehicle about two inches. i did balance my wheels just a few months ago and all the weights are on. any help will be highly appreciated!! bt
Old Nov 12, 2015 | 07:16 PM
turboed350z's Avatar
turboed350z
Did you adjust camber and toe accordingly? Lowering a car is more than just springs and calling it a day.
Are the spacers and wheels tighten?
Wheel and tire balanced?
Old Nov 12, 2015 | 07:20 PM
max.e.urena
yeah i just had it aligned yesterday. everything is buttoned up. ill reinstall them again hopefully it helps.
Old Nov 12, 2015 | 07:21 PM
dcains's Avatar
dcains
It's not the endlinks. I'd look at the spacers.
Old Nov 12, 2015 | 07:31 PM
nizmo_0385's Avatar
nizmo_0385
Spacers. Over torque lug nuts or under torque. Wheels out of balance or tire issue?
Old Nov 12, 2015 | 07:46 PM
max.e.urena
i had the tires mounted and balanced 3 months ago and the car didnt shake before the coils. i think its the front spacers...
Old Nov 13, 2015 | 03:17 AM
VenomGT9's Avatar
VenomGT9
Spacers most likely
Old Nov 13, 2015 | 05:42 AM
JCat's Avatar
JCat
Too many shops adjust our -Z-'s based on a number in their book.
Since you have altered and changed the stock suspension, the book numbers are no longer valid.
You need to find a better shop that knows how to setup performance suspensions. These shops are difficult to find. (My suspension was tuned by a guy who is on a NASCAR team . . . he knows his **** and he really did a good job.)
or get one of these:
https://my350z.com/forum/maintenance...l#post10680708
Old Nov 13, 2015 | 06:10 AM
terrasmak's Avatar
Retorque the spacers, I bet you have the crappy bolt on kind. Studs were probably not settled
kgman1000
Jul 7, 2020 05:32 PM
sauer420
Aug 27, 2016 06:12 PM
