Subframe studs broke help.
Old Nov 27, 2015 | 10:12 PM
beefy350's Avatar
beefy350
Default Subframe studs broke help.
Hey guys, been lurking here for awhile and finally got into a predicament that I need to ask about. I have a z that I bought for a drift/track toy a little over a year ago and I've been slowly catching up on some long neglected maintinence and doing upgrades along the way. To make a long story short, in order to replace some rusty bits underneath the car and all the rear subframe/diff bushings I dropped my subframe today. Now, this car has spent it's whole life in the rust belt, and I always take precautions against seized hardware (heat and loads of pb blaster) but I had some bad sh*t happen this time... 3 of the 4 subframe studs broke off before the nut came all the way off. (I'll give everyone reading a minute to internally panic the way I did)........... now, I know they are pressed in like wheel studs, and I know I can holesaw the rear floors, and pound them up from the bottom..... but does anyone know where to buy replacement studs? Also, would it be unreasonable to simply get a couple large bolts and washers and just run them in place of the studs? Also have read about cutting the threads off and having a threaded piece welded onto the rest of the stud? This is a fairly common thing on 240s from I've read and those guys have a couple similar solutions. Anyone with experience here is welcome to chime in. Thanks everyone.
Old Dec 1, 2015 | 03:12 PM
zakmartin's Avatar
zakmartin
Since you're in the rust belt anyway, if you can make it work, then go for it. Grade 8 bolts, slightly beefier than the stock studs should do the trick. God only knows how many out-of-spec bolts I've put on the Mustangs and Fiats I've restored.
Old Dec 2, 2015 | 08:15 AM
iideadeyeii's Avatar
iideadeyeii
I personally wouldn't weld something on to the stud.
I would cut the floor and replace the bolts with some universal grade 8 hardware.
35reilly
Jan 16, 2016 04:43 AM
TheMambanator24
Wheels Tires
Dec 28, 2015 04:38 PM
Joe clan
Nov 28, 2015 10:38 AM
WTFMike
Nov 27, 2015 11:38 PM
MikeBit
Nov 26, 2015 11:39 AM
